iron or steel distributor gears?
Discussion in 'The Garage' started by dirtynails, Aug 21, 2006.
  1. dirtynails
    dirtynails Registered Member
    Aug 28, 2005
    96
    Gosport, Indiana
    I have a Chevy 350 universal crate motor installed on my '83 Blazer and want to replace my original distributor which is an HEI/ESC and went on the original 305 motor. I am looking at a Summit racing distributor with steel gears and a Mallory 85 with iron gears. Does it make any difference which should I choose? I don't want an improper gear material to eat the cam shaft, right?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    If its a hyd flat tappet, you want bronze gear IIRC, steel if for roller cams.
    I could be wrong though.
  3. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Depends on your cam. If you're using an OEM style cam, iron is preferred. For an aftermarket roller cam bronze is usually required unless they are using an OEM style drive.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    bassackwards.
    Unless, as noted, you have an OE roller cam.
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    There ya go. I was a backwardass
