irritating squeak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjames, Dec 18, 2001.
  1. jimmyjames
    jimmyjames Registered Member
    Dec 18, 2001
    13
    NH
    Hi, I've got an 88 jimmy full size. It's got a nasty squeak right behind the passangers door under the truck. I sprayed silicone spray and WD40 on the shock bolts and the bolts that attach the leaf springs. the dam squeak semes to be near or in the rear cab mount. I have sprayed up their with no luck. It squeaks all the time, I rock the in my drive way and I can hear it.can any one help? (stock hight and tires)
    thanks for your help
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    It does sound like a worn body mount. I paid to have mine changed on the body for the same reason. You might also want to check the mounts at the rad support. Also check to make sure the seat bolts are tight as well.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  3. jimmyjames
    Dec 18, 2001
    13
    NH
    The seat bolts are tight and the body and frame mounts are not worn and tight. This thing has got me stumped. Thanks for the help so far.
  4. Grim-Reaper
    7,385
    Atlanta
    Have you got polly bushings in the rear springs? Check the bushings. I had one slip and let the spring touch the spring hanger.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  5. shawnboy
    Jun 22, 2001
    468
    Also check fuel lines, your fuel filter is in that area check for tightness. As well check the filler neck on you gas tank the hose clamps on the rubber extension could be loose, The top shock bolt at rear could have rounded out the hole and be squeeking as well. You might no be able to feel that the shock is loose because of the vehicles weight but these things are famous for that one.
    Shawnboy.
