Is 1.5" tubing enough for a cage
Discussion in 'The Garage' started by bajaviking, Mar 7, 2005.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Is 1.5" tubing enough for a cage if you triangulate all the corners. Also, what pipe bender do you guys recommend, it will only be for my own use and I don't wan't to spend a bunch of money on it.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1.5" TUBING is fine
    Bending it with a "PIPE" bender is NOT!
  3. bajaviking
    Apr 10, 2002
    752
    Baja
    Please excuse my ignorance but what is the difference?
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Pipe is for plumbing, conduit is for elecrical, and tube is for structural. I think 1.5" tube is a bit on the small side for a fullsize cage. It is fine for support, and gussets, but the main structure should be something bigger.
    As for benders, look at an M-Tech or JD2 (same design). There are plenty of benders to choose from. A complete tubing bender will set you back over $500 to start bending one size of tubing.
    Also a roll cage is the worst project for a beginner fabricator.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    wall thickness is also an issue. Most guys that use 1.5" tube on buggies and such are using .120 wall. If you ran .134 or .188, or made a cage that was like a jungle-gym of tube, you'd prolly be fine. It also makes a difference whether its DOM or not. Someone over on pirate posted a little graph showing the relative strength of various sizes of tube, and hrew vs dom. DOM definitely had an advantage. Anyway, I'm gonna make mine out of 1.75 x .120. Prolly hrew cause I'm cheap... prolly a jungle gym because I actually like the look. ;)
    j
  6. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Pipe is defined by it's inside diameter (and it's schedule)
    Tube is defined by it's outside diameter and it's wall thickness.
    1.5" pipe (sched 40) is 1.90" outside for example, 1.5" Tubing is 1.5" outside.
