Is $300 too much for a front Dana 60??
Discussion in 'The Garage' started by gmcsrgr8, Dec 8, 2002.
  1. gmcsrgr8
    gmcsrgr8 Registered Member
    May 3, 2002
    12
    Utah
    HOUSING, that is.
    I found one in the paper today and was wondering if this would be cost effective. How much would it be to build one up? Does anybody out there have any experience with this?
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i'd offer 200...
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    inner axle shafts $200
    35 spline kit w/ujoints + lockouts $360
    Brake calipers no core $120
    Carrier + gearset $?
    carrier bearings set $120
    Wheel bearing hubs $400
    Rotors $200
    .... bling bling
    There's a reason Dynatrac axles cost $6500. I'ld hold out for something more complete
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've seen them on eBay sell for half of that.
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It depends on if you would want tor ebuild right away.
    Say, if you wanted 4.88 w/ ARB or detroit. Then it doesn't matter if it had the guts.
    I understand many inner shafts are necked down - non necked down ones are $100 each. If you'd replace them anyways, then no big deal.
    All would be 30 spline outers - again, if you want 35's it doesn't matter if it's there.
    What you DO want is the wheel hubs and bearing caps. Without those two items, it really is a lost cause.
    My opinion, of course.
    -- Mike
