Is a 1-Ton Master Cyclinder better?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zakk, Apr 23, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I am having (among others) problems with the brakes. A buddy of mone floated the idea that I still have the 1/2 ton master cyclinder and should upgrade to a 1-ton M. C.
    Is thebore different? would it really make the breaking better?
    thanks for any input!
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    bore size changes required pedal pressure and length of stroke.
    assuming you are not bottoming out the master it will not really effect braking performance.
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    A lot of people have swapped the 1/2 ton master cylinder in favor of the 1 ton, after doing an axle swap. I plan on changing mine soon, my brakes don't feel up to par after going 3/4 ton.
  4. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I didn't swap out any master cylinder and my brakes are the one thing on my truck that works flawlessly
  5. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I'm pretty sure if you swap out the 1/2 MC to a 1ton MC, then you'll need to swap the Booster as well. Not 100% on that though. But I kept the 1/2 ton brake stuff and even have the rear disk setup and the brakes works really well. Had it for about a year now...
    Boss
  6. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    I went with the rear discs and needed to change to 1 ton master because calipers require more fluid volume than the wheel cylinders did. Some people just change out the proportioning valve, but I found the most cost effective way to handle it was to swap out masters. Went to autozone, 25 bucks, lifetime warranty, and bolted right up to my booster. Good luck!
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    You would need a booster too.
    1/2 ton stuff stops my D60/14BFF fine. Must be something else wrong. Did you powerbleed the system?
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I would recoomend changing to the 1 ton MC.
    Boss and Blazzin OR... just to let you know, I used a 1 ton Mc on my 82 and didnt have to change the booster. Thats not to say that holds true on all of the years, there was a major improvement in braking.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm running the master cylinder from a 1980 Trans Am with 4-wheel disc brakes. It has resevoir capacity to feed the rear calipers on my 14-bolt. /forums/images/icons/cool.gif
  10. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Cool that it works, but the reservoir size has little to do with whether or not the MC pushes enough fluid to cover the movement of all wheel cylinders and caliper pistons. The bore/stroke determines how much fluid is pumped not the reservoir. A big reservoir is good so that you make sure there is enough fluid that the MC doesn't run short, but it won't add any volume to the MC itself. Unless I'm missing something.
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The resevoir size becomes important when you run rear disc brakes. Take a look at the tiny resevoir for the rear brakes on a vehicle with drums out back. If you don't keep up with the fluid level as the pads wear, the resevoir can get quickly sucked dry. As the pads wear, the pistons move further out in their bores. Since the bores are so much larger than the bores of a wheel cylinder, they need a lot of fluid volume to keep the space behind them filled. /forums/images/icons/frown.gif
    As for the master cylinder bore size, the Trans Am master cylinder has no trouble locking up all 4 of my 35-inch BFG muds. /forums/images/icons/cool.gif
  12. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    With the dual piston front calipers on the 60, and the late '70 3/4 ton calipers out back, and NEVER touching the MC, my truck can lock all 4 36 TSLs. Granted it drinks more fluid (as Harry stated above), but it sure does stop my rig in a big rush. /forums/images/icons/cool.gif
    Anyone tried power bleeding their brakes before replacing the MC? I too was having problems at first, but then one day I got mad, and ran something like 5 gallons of fluid /forums/images/icons/crazy.gif thru the system to be SURE the air was out. Since then, I have had ZERO problems with my brakes.
    -Dan
  13. Leadfoot
    Nov 28, 2000
    3,112
    The reservoirs on the MC are designed to provide more than enough fluid to keep the bore/stroke filled (in most cases you don't use all of the volume of the piston and if you did you would be flurting with disaster as there is a built in buffer which is why most can use their stock MC for discs but MAY not be a good idea as the pads wear and more fluid is needed IF they don't keep the fluid topped off and don't have a good enough buffer). Each time you hit the brakes the stroke should be roughly the same but as the pads/shoes wear more fluid is needed to take up the "extra" space so that is why topping off is sometimes necessary. The only problem is when you go to put new pads/shoes on, you may have to remove some as to not make a mess as the fluid that was making up for the wear is pushed back into the MC. If you run out of fluid (assuming you keep it topped off), you have bigger problems than needing a bigger reservoir. If you do, you don't need a bigger reservoir, you need a bigger MC or at least one with a bigger chamber for that circuit. Sorry if I was a little vague at first. Bigger reservoirs are necessary for bigger MC's and help so that you don't have to keep topping off, but if the stock reservoir is not enough, then you need to get a bigger bore/stroke to match your needs. It more a question of safety.
  14. BurbinOR
    5,829
    Oregon
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Good point...........I had to do that after the one ton axle conversion and almost went through the windshield after I got the truck back...............huge difference.
  15. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    I just took my truck for a test drive after the rear one ton swap and it doesn't stop for crap. A buddy said I need a new proportioning valve and a MC. The thing is I never listen to my buddies, especially on the trial! "go for it" Anyway, I think I will try a powerbleed and see if that does the trick. What did it cost to do the power bleed?
  16. BurbinOR
    5,829
    Oregon
    About $50ish. Make sure your rear drum brakes are adjusted out too.
  17. 91gmcjimmyCH_IL
    May 24, 2001
    110
    Grayslake, IL
    Is there any way to see if a prop valve or an MC is bad? if there are no visible leaks.
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Adjust them tighter and get the rest of the air out. Let them gravity bleed a while if necessary.
  19. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Anyone ever try use one of those reverse fluid injection kits as an alternative to powerbleeding? The kit is about $50, which pays for itself the first time if it works. You have a small tank of fluid on the tool and it connects to the bleeder screw and forces fluid back up through the system into the MC. The idea is that air tends to rise in the fluid, so it is better to move the fluid up through the system instead of down. Only problem is that you need a good way to get the excess fluid out of the MC while you do it.
  20. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    That is all I did after the 3/4 ton swap.
    At work we have a gallon jug with a pump and a hose that fits over the bleeder screw, after bleeding the master almost dry on both front and rear I just back bled the system, I had adjusted the bakes prior to that and after I back bled the system I had a solid pedal and it it will lock em up with no problem.
    I had to relearn to brake they were stopping so well, I kept hitting them to hard and would lock it up.
    Before I had to realy lay into it to get it to slow and the first time I did that I was glad the seat belt was on.
