Is a 205 the only one that looks like this??
Discussion in 'The Garage' started by Skyetone, Apr 20, 2002.
  1. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    IT SAYS IM NOT THE OWNER OF THE ALBUM .
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Same here. /forums/images/icons/tongue.gif
  4. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    gues what i got yesterday Wes !??!?! muhuahaha sorry to be off topic..
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i used the other link and found it in the tech album , that IS a 205 .
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    My 205 looks just like that.Heres a pic of mine.
    <a target="_blank" href=http://www.imagestation.com/picture/sraid5/p1860bd4f031d35d30adbbfe10b667c21/fe440618.jpg>http://www.imagestation.com/picture/sraid5/p1860bd4f031d35d30adbbfe10b667c21/fe440618.jpg</a>
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yes, the NP205 will be the only one to have an inspection cover on the back held on by three botls.
    -- Mike
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Correction, Mike, the 3 bolts hold a round cover to hold the idler shaft in place, not as an inspection cover. /forums/images/icons/wink.gif
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Hmmm, I've never taken mine off so I didn't know.
    -- Mike
  10. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    Can't you inspect the Idler shaft from there?
    hehehehehe
    Sorry, I'm bored...... /forums/images/icons/smile.gif
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, because all you will see is the end of the shaft. The shaft holds a big "dual" gear in to keep it from walking back and forth.
    If you notice on the opposite side of the 3 bolt cover, there is a nut which also holds the whole shaft together. /forums/images/icons/wink.gif
  12. ratpack7
    ratpack7 Guest
    Dam Sky youve only had that Blazer a couple of weeks and you all ready have that many pics of it?
    I've had mine coming on 3 years and I have 1 polaroid.
  13. ratpack7
    ratpack7 Guest
  14. Skyetone
    Apr 10, 2002
    118
    SLC Utah
