Is a 427 crank differnt in a 2 ton?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by RingMaster4x4, Mar 5, 2001.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    Bartlett, Texas
    I have a question.The 427 is coming out of a 2 ton truck and a guy told me that the crank may have a bigger bolt pattern that a TH 350 flywheel. Is this true?
    72 K5 blazer w/350/TH350 NP205 6" lift 31" tires.
    Soon to be 1 ton with a 427 tall deck and TH400//NP205 and 12" of lift with 40" tires.
  2. thatK30guy
    Jan 12, 2001
    It shouldnt be different than the regular 396, 427 cranks. The only difference in the truck 427 and car 427 is the truck block is almost 1/2 taller deck. All the cranks are the same except for the 454, which has its own crank.
