Is a 700R and NP203 combo possible
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WARP1, Apr 5, 2001.
  1. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    Could I put a 700R trans in my Blazer and keep my NP203 T-case? What would I need to modify to get these two to bolt together?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Advance Adapters makes the parts you need to do this. Check out <A target="_blank" HREF=http://www.advanceadapters.com/BUYERSGUIDE/acrobat/gm.pdf>http://www.advanceadapters.com/BUYERSGUIDE/acrobat/gm.pdf</A>.
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes it is possible, how much do you want to spend $$$$$$$$$$$$$$$$$$$$$$$$$
  4. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    You'll need the tailshaft the fits the 203 ($170 from Advanced Adaptors, also fits the 205) and you'll need to lengthen the side torque strut, shorten the rear drive shaft and lengthen the front drive shaft (about 1 and 3/8"). You may also have to modify the hole in the floor pan where the shifter goes (otherwise you won't get 4-hi). Also the crossmember will have to be moved back and new holes drilled. The steering column (1981 and earlier) will have to be swapped out for a 1982 or later model, unless you don't ever forsee using D1. Other than that, it's a piece of cake.
  5. Executioner
    Feb 22, 2000
    1,530
    May I suggest a NP208 transfer case ?
    If you really must have the NP203 go for it, I don't know your appliction/use, but the NP203 is getting
    old, and the chain will strecht/wear out, someday, even if you just rebuilt it.
    Its kinda heavy !
