Is a cat necissary?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnnieg, Apr 10, 2003.
  1. johnnieg
    johnnieg 1/2 ton status
    Nov 10, 2002
    130
    CSU, Ft. Collins, CO
    How much does a catalytic converter drop emissions? I did my emissions about a month ago and the readings are way below the limits.
    HC ppm limit=400 idle=135 2500rpm=41
    CO% limit=1.50 idle=.69 2500rpm=.38
    Can I gut it and still pass? /forums/images/graemlins/k5.gif
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    cat does a lot...without it those numbers will be really high...like HC's in the 2000's and CO% in the 10-20...thats what mine was putting out whit a bad cat.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    No, a cat is not necessary, my dawgs hate them. /forums/images/graemlins/grin.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't gut it. You can put a pipe through it, but don't gut it.
    You'll most likely still pass without it. The cat does drop emissions dramatically, but I bet you can still pass without it if your engine runs the way it should.
    A bad cat is worse than no cat cause it'll make your engine run like $hit. A properly running engine that's 15+ years old should pass all but California's standards without a cat IMO.
    Do this at your own risk. It may not pass.
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    we dont gatta worry bout that stuff here..my dad puts the inspection stickers on our vehicles! /forums/images/graemlins/thumb.gif me and my dad have duals with out any cats..just mufflers and thats it.. i got headers,duals with dynomax's..and thats it no tailpipes ur nothin... sounds awesome too!
  6. dyeager535
    26,979
    If the things working correctly, and not too old, don't waste your time.
    Newer cat converters cause very little, if any restriction, and since you have to pass emissions, why make it hard on yourself?
    Again, thats if the cat is good.
