Is a D60 rear enough
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 Shortbox, Jan 25, 2002.
  1. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    I have recently been offered a dana 60 rear out of an old dodge for $400 with new ring & pinion and a Detroit locker. I guess my question is, in this day of 14bolt FF is a dana 60 rear enough? I only plan to run 35's. I figure anything is better than my 10 bolt open diff.
    "We all gotta go sometime.... Race ya"
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    seems kinda pricey to me, i can pick up 14FF all day for $150. for $400 it better be in great condition.
    gime a bucket of chicken with extra skin!
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am running a D60 rear w/MarkWilliams HighTorque 35spline axel shafts and a DanaPower-Lok & 4.11s w/35x12.50-15SSR Swampers! Seams tuff enough for me!!
    I picked mine up for 250 about 6yrs ago....it came out of a late 70's GMC long bed 4x4 P/U
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  4. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    I would check the axle spline count. If it is one of the fine spline models and has the gear ratio you want than $400 sounds like a good deal. Don't forget to figgure in the cost mounts if you are not doing it your self. A 30+ spline D60 will be plenty for 35s. Last time I checked a Detroit for a D60 was more than $400.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  5. 85 Shortbox
    Jan 24, 2002
    138
    Grandville, Mi
    I have had a lot of people tell me they can pick up 14 bolt FF's for good money like that, but for some reason they are harder to come buy around me. I have checked junk yards, swap meets, classified adds for months and have come up with zip. As for expensive, the guy I am buying the axle from broke it down like this. $100 for axle complete drum to drum, $200 for brand new detroit locker, $100 for brand new gears. And he is going to install them both at no charge. He got the locker and gears from a mutual friend of ours that bought them both brand new to put in his plow truck, but then sold the truck. Anyway, that is why I am willing to pay a little more.
  6. beater74
    May 29, 2001
    1,749
    atlanta
    when ya break it down like that sounds a whole lot betta. it's almost worth it just for the locker
  7. 85 Shortbox
    Jan 24, 2002
    138
    Grandville, Mi
    What about the front, I am sticking with just the 10 bolt (converting to 8 lug of course) is this an Ok axle? What kind of locker/limited slip is recommended if any?
  8. Burt4x4
    6,854
    Ya that is a fair price!
    I have a D44 front but the 10 is perrty much the same. You can BEEF up your 10 bolt by spending about 800bucks at WARN but alot of folks will say "Just get a D60 front and be done with it"!!
    Sup to you a D60 can be anywere from 800(smokin deal and rarly found at this price but not impossable) to 3000+(place like DynaTrac or Boyce ) so..........
  9. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Arear Dana 60 is not bad, especially with 35's. You also get about 1" of extra ground clearance when you compare it to the 14 bolt.
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  10. Grim-Reaper
    7,385
    Atlanta
    D60 is a good axle and if it is what he says it is that's probably a fair price. The upside is the pumpkin on a D60 is smaller than a 14 so you will have better clearence.
    Strength wise...14 is on d70 level however a D60 is pretty stout.
    The front your in the gray area with strength. Leave it open and be easy with the right foot and it will probably be ok. If you atart snaping shafts going to a better shaft may solve the problem.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  11. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    d60 is a strong axle...ive seen them run 39s and hold up fine...10 bolts are actually a decent front axle...they are a bit stronger than the dana 44 but not as strong as a dana 60...i just finished my 14 bolt swap and i am leaving my 10 bolt up front...im gonna put in some better shafts and convert to 8 lug and leave it open...
    Later
    Have you driven OVER a Ford lately?
