Is a Ford 205 Doubler the SAME as the Chevy 205 Doubler....???
Discussion in 'OffRoad Design' started by Greg72, Jun 7, 2004.
  1. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Stephen,
    My brain is hurting, and I'm a little concerned that I'm not going to like the answer anyway.....
    Ford 205 has the front output on the opposite side as Chevy, so does that mean that the Doubler for Ford is a "mirror image" of the Chevy one???
    Is there any chance that I can use the same 2" upclocked Doubler I already own, if I decide to change my mind and utilize a Ford 205????
    BTW -> This is a sidebar discussion from the Unimog 404 axle thread currently running in "The Garage"..... I never saw portal 'Mogs in person until this weekend, and now I think they are the coolest thing since, well... sliced bread.
    /forums/images/graemlins/peace.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Not Stephen, but I think at best your going to wind up 2" clocked down, assuming the pattern is symetric. Also round or "8" pattern on your adapter? All Fords are round AFAIK.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I think you're out of luck on this one. The adapters are totally different, to the point that you should probably start over. It's not a problem to put the ford 205 behind the GM 203 that you have but even if you had the round pattern GM adapter the 205 bolt patterns are quite a bit different (similar pattern, different rotation) and the cutout for the shift rail is in a different spot.
    I haven't been over to the 'mog axle post but you're right, they are pretty cool stuff.
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Looks like it's now time to post up in the "For Sale" area..... /forums/images/graemlins/grin.gif
  5. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Which Doubler set up do you have? /forums/images/graemlins/whistling.gif
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    The "standard" Chevy one with the 2" uprotation of the 205.....
    /forums/images/graemlins/waytogo.gif
  7. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    TH350 or TH400? Figure "8" pattern?
  8. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    If I was going to order my doubler again, I would not get the 2 inch up rotation. It will give you more transmission, and oil pan clearance for the 404 axles. It will work with a 2 inch up rotation but the clearance is pretty close. /forums/images/graemlins/truck.gif
