Is a gear upgrade necessary
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Jan 26, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    i plan to add a four inch suspension lift to my 89 Jimmy(on top of the 3 inch body lift) and throw either 36 or 38 inchers under it. I have a stock 350 with a 700r4 trans should i upgrade my gears and if so what should i upgrade to, also if you think i should ugrade other stuff dont hesitate to let me know
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You didn't state what your gear ratio is now.
    It is probably 3.73.
    For the 36's it will work, but will be a dog.
    I say no way for 38s.
    Those are big tires and the stock axles, esp. the rear, won't be up to the task long-term.
    Upgrade #1 - bolt-in steering brace.
    -- Mike
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    With the 700 I wouldn't run with 3.73's or (numerically) lower gears. If you plan to run 36's, I'd go with 4.56's, and if you use 38's I'd install some 4.88's. These combos would give good on and off-road performance.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you go with 38's go with 5:13's since you have the overdrive /forums/images/graemlins/smile.gif if you are going to go with and stay with 36's go with 4:88's
