is a multumount strong if not would pipe be ok
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5texan, Nov 6, 2001.
  1. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    i was thining about making a front bumper out of 3x6 tubing and putting a reciever hitch in the front so i can mount the winch on front or back. if that wont work should i make the front were it is permently attached out of tubing or will pipe be ok. because i can buy a pipe bender a lot cheaper than a tube bender.
    thanks
    jared
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Re: how strong is a multumount
    If you pull from the side with a multi-mount it will break. I think it is more of a novelty for a mall runner than a really useful accessory.
    I thought I was wrong once,
    but I was mistaken
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I dont' have a place to show pics on the web but i'll send you pics of my multi mount. I built my own using box tubing, but instead of one reciever i used two. I have pulled alot of people out, done side pulls, used snatch blocks, etc and it won't budge. I have the receiver built into the front and rear bumpers. Let me know if you want more info. Later - Doug
    Doug Krebs
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I could see two recievers being quite a bit stronger!
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Duel mounts also helps prevent twisting the mount when pulling to one side (or rather, not dead ahead). I wouldn't even consider a single mount like that.
    Hehe, just to go a step further, maybe even an extra mount on each side in the rock sliders? That could be used to easily right a rig that has gone belly up (or on it's side). You could even use it with the remote to walk the vehicle out of a bad situation while using the wench to prevent a roll and letting it in/out as necessary to keep ballanced. Much better and safer than some of the human ballast efforts I've seen used. I was thinking it would be nice to have a setup like this built into my rig when I get to the cool stuff. Wouldn't take that much to graft a couple of extra receiver pairs into some 3" rock sliders. The receivers could then be run back and tied directly into the frame as part of the slider mount. Just some things that crossed my mind. [​IMG]
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    take a look at the pics in the album my blazer in the webshots link in my sig and take a look at mine i used square tubbing on mine and it works awesome i can get better pics of how it is mounted to the frame if you are interested
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  7. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    I saw a home made multi mount but the reciever was solid steel like the 10,000lb hitch type wonder what would break first.
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.11
  8. k5texan
    Aug 1, 2001
    119
    Flint, TX
    thanks for all the advice i am still debating whether to do a multi mount are have just it on the front. if i do that would tubing be better than pipe or does it not really matter.
    thanks
    jared
  9. Grim-Reaper
    7,385
    Atlanta
    Take a box full of bricks that weighs about 90lb. Go find a mud hole about rocker deep and park your truck in the middle of it. Set the box of bicks way up in the truck so you have to drag your muddy self into the back of your truck. Then drag it out. Carry it around to the front of the tuck. Repeat this a few times. This will give you an idea if you want a multi mount.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hehe, too funny Grim! [​IMG] Personally, I had more in mind leaving it stuck in the front unless I need the clearance/approach angle, then it could be moved to the back or bed as required. I don't see this as requiring any more effort or forethought than other solutions (run the cable under the truck before hitting a hole to avoid crawling under). It just gives more options and clearance when needed.
    Russ
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  12. Grim-Reaper
    7,385
    Atlanta
    There is a company that makes a winch set up that looks like a regular winch bumper. It has a removable winch deck and double recievers so that it can be side loaded. Then a double reciver set up for the back. There was a write up about 5 years ago in one of the mags. It's a Canadian company that makes it but I don't remember the name. Had the Canadian Maple leaf cut into the sides of the brush gard uprights. The Canadian mounties or some rescue units had awarded them a contract to supply them for their rescue vehicles. I had thought seriously about building a simulare set up. It's pretty complicated to do and have it come out looking respecatable. I follow the rule of never wheeling alone. So if I need to get yanked back there should be somebody behind me already.
    75 Jimmy, Dollar
    Grim-Reaper
