IS A New Oil Pan That Hard To Get????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Canuck, Jun 30, 2000.
  1. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    The previous owner of my '86K5 must have run into something extreme because The pan was bashed out and a plate was welded across the bottom and half way up the side. It leaks like a son-of-a-B%$#H.
    Anyway, I went to order a GM replacement and they said first of all it was $200.00 (Canadian) and secondly, I couldn't get one because there is no stock on them. By bro told me that they had a problem with rusting out.
    1986, 305, no rear main seal. Passenger side dip stick. Is there a GM quality repacement out there??
    Canuck
    Go Wide or Stay @ Home
    Blazers Forever
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Check out a summit racing catalog, they have them at great prices, so do Jegs.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    Canuck as far as I know, you can use any 4x4 oil pan for a small block. maybe even a 2x4 pan. I did this on a suburban. just match the pan up if you get another one. You can pick one up in a junk yard for 40 bucks or so..As for the rear main its a two piece or a one piece. Two piece pre-86, One piee 86 and up. Then again it was a retooling year for those motors so check your heads.....I believe with center bolt heads you have a one piece rear main. Anyone out there can correct me if I'm wrong.
    A very, very important point about your "smashed" pan is the pick-up from the oil pump, the clearance is very close to the bottom, and with even minimal damage to the pan you can crack the pick-up tube i would change the pump and pickup to high volume, not high pressure unit....good luck
  5. Canuck
    183
    Eveything looks OK. The pick up must have been changed. The pan utilizes a one piece seal. GM needed the actual production date of the pan. I guess there were a few different ones for that year. I already went through the used part and it didn't fit. Piss me off, especially after I cleaned and painted it up. No more messing around, I would like a new one.
    Thanks for the info.
    Canuck
    Blazers Forever
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
