Is a NP203 divorced or married?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zakk, Nov 6, 2001.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    trying to figure out where the fluid is coming from & i don't know if the 203 is divorced. also, can you run dextron (sp?) in a 203 or just gear oil? i see a crack in the t-case, but it's tranny fluid coming out.[​IMG]
    as always, thanks to all who can help!
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    First if the t-case is mated to the tranny then it is married.
    A divorced t-case has a drive line from the tranny to t-case.
    2nd a 203 uses engine oil for lube. 10w40.
    If you have tranny fluid leaking from the t-case then the input shaft seal is wasted on the t-case.
    And if it is cracked then ya got problems all over.
    Are ya sure it is the t-case that is cracked and not the adapter?
    That is the piece inbetween the tranny and t-case.
    The 203 is cast iron and pretty tough.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i see a crack on the "belly" of the t-case. it is "forward right" of the front driveshaft. it might be the adapter, but would that allow tranny fluid to flow like a river?
    -Zakk
  4. Grim-Reaper
    7,385
    Atlanta
    The ataptor has the seals from the tranny to the case. The adaptor will have ATF in it. If your case has oil in it then you have a leak around the adaptor. Ig the case was cracked and you had oil in it then you would get oil not ATF. Now be sure it's a crack your seeing and not casting marks. When they make the moulds for the housings there is often lines where tha halves meet. This will leave a line in the metal that can at a glance look like a crack.
    Worse case you might have a cracked addaptor and the 203 adaptors are pretty pletifull in junk yards so it sould be that expensive. Just a pain to replace.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so i might just be needing an adapter...great, right after i buy a 465/205 combo and a 350/203 combo[​IMG] oh well. if it is just the adapter i will be stocked. i will try to get a digital pic and post it to see what you all think. I was getting ready to just drop the t-case and tranny and see what the hell was busted.
    -Zakk
  6. Grim-Reaper
    7,385
    Atlanta
    If you need that adaptor Waxer has one for sale in the parts section. He's even on your side of the country [​IMG]. I have bought parts from him (infact parts off the 203 the adaptor came off) and he's a straight up guy. He won't screw you.
    75 Jimmy, Dollar
    Grim-Reaper
