Is a NP241 that bad?
Discussion in 'The Garage' started by BowtieRed, Jul 22, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    I want an NP205 but if i can get a 241 a lot cheaper, should i? i mean is it THAT much weaker?
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    actually the 241 seems to be catching on, mainly because of its 2.72 low range but it is a pretty strong t-case, i forgot where i was but i read a guy saying he was going to take out his 205 and replace it with a 241 for wieght savings, with a SYE and mayby a clocking ring in the future i think its pretty good
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    There's not too much wrong with a 241. It's just a glorified 208, but IMHO, the 208 is better. Given, the 241 has a 2.72:1 low range compared to the 208's 2.62:1, but I'd still take the 208. The only difference is a modified oiling system, and the option of mechanical or electronic speedometer. That's pretty much all you have to look out for. Rebuilding it is easy, and the kits are fairly cheap, but they make you buy the chain separate. Both the 208 and the 241 can be converted to fixed yoke, so it's all a matter of opinion. Just be sure to run a good skidplate because aluminum doesn't like rocks.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The 241 is a pretty good t case. All they really need to do now is come up with a 4to1 low kit for them. /forums/images/graemlins/tongue.gif
  5. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    They actually do have that, but in our trucks they would break too easily. Something about the planetaries in it are so small after the 4:1's are in.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Just wondering why you think the 208 is better than the 241? As you pointed out better oiling & lower low range. Add in a more robust case (that sill needs a skid plate) than the 208 and it looks like the 241 the winner hands down.
  7. cjblais
    cjblais Registered Member
    May 8, 2003
    25
    New Hampshire
    The 241 is better than the 208. The 208 had problems with the rear case half cracking due to age and load. There is no 4:1 low range for the 241 yet there is one for its little sister the jeep 231 though. A SYE (slip yoke eliminator) is a must. All in all a good general t case.
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    that was my point
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Actually the Jeep Rubicon has an NV241OR which is a 241 and has 4:1...
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    would the swap be any harder than a 465/205 swap? this is off of a 89 K5.
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The 241OR has a totally different set of planetary's than the regular 241's . They are much larger to handle the steep reduction ratio. The case is different to accept the larger gear set too .
    From what I have seen the 241's are a fairly good case - it is no 205 but for what it is they are moderately strong. It would be nice if the parts from a H.D.241 out of a later model H.D. Dodge would fit a regular 241 - they have thicker chains/sprokets an extra bearing on the main shaft and a MUCH larger rear output shaft along with a better type of case material .Just as a note - not all H.D. 241's are created equal - there were several revisions as the years went by.
    Tom
  12. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Some place did make a 4.1 kit but they make it for just the 242 now. i will have to look and see if i can the info.
  13. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    would a 465/241 combo bolts up as easily as a 465/205 combo?
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes and no. Once you ahve all the right parts it would bolt up as easy. You would need an adapter for the 465 to go to a 241, not sure if GM ever used that combo and if not you'd have to check with Advance Adapters or Novaks.... Although the 208 adapter may work.. Once you had the adapters and the driveshafts the right length it should be an easy bolt up.
    With the 465/205 combo you can basically use "factory Gm" parts t bolt the combo up...
    I have beat my 208's for quite a few years without problems. What type of wheelin do you do or is your K5 more of a DD? You should be fine with a 465/208 or 465/205...
  15. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i would think this rare but
    Year: 1991 Production Total: 7,332
    Base Price: 17,590 Weight: 4,507
    Wheel Base: 106.5 in. Fuel Tank Capacity: 26-gallon/31- gallon
    Length: 184.8 in. Height: 73.4 in.
    Std. Engine, (HP):
    OHV Eight-cylinder 350 cid. (210) @ 4000 rpm
    Opt. Engine, (HP):
    OHV Diesel Eight-cylinder 379 cid. (130) @ 3600 rpm
    Rear Axle:
    GM Corporate 10-bolt (8.5-in. 1.28 Axle Dia. 30 Spline)
    Front Axle:
    Transmission (M):
    SM465 4 spd. (6.55:1 First Gear)
    Transmission (A):
    4L60 * (3.06:1 First Gear)
    Transfer Case (M):
    NP241 (2.72:1 Low Range)
    Transfer Case (A):
  16. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've said that and I will most likely do it maybe this winter. I stopped running deep mud so it looked like a cheaper way to get a lower low range.
  17. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok, this combo is already bolted together. is there anything else that would be hard?
    and SM465 came in 87-91 with NP241 tcase. ANYWAY it's already bolted up, would anything else be harder than a 465/205 swap?
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    Well the only other areas you would need to worry about are crossmember placment(if your vehicle wasn't equipped with this) and driveshaft lengths/u-joints..... You may need ot drill new holes for the crossmember mounting and you may need to lengthen or shorten your driveshafts. Also, your u-joint sizes may not match up...
    One last thing, is the 241 a mechanical or elec. speedo hook-up?
  19. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    idk. . .but i don't use my speedo right now. . . lol it says about 30 when i'm doing around 38
    well if i could do speedo readin x (4.88/3.73) in my head then i'd be fine /forums/images/graemlins/laugh.gif
  20. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The first year for the 241 was 89. Nobody makes a 4to1 kit for the GM case yet. I have spoke with a few vendors about this and from what I have been told it is in devolpment but nothing concrete.
