Is a shackle flip beneficial if I'm....
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by slayer77, Dec 14, 2003.
  1. slayer77
    slayer77 Registered Member
    Oct 21, 2003
    29
    Pleasant Hill Ca.
    Is a shackle flip beneficial if I\'m....
    putting 8" leafs on a 71k5?
    Thanks,
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Re: Is a shackle flip beneficial if I\'m....
    If I understand it correctly, and you are going to be putting on 8" lift springs on front and rear, no a shackle flip would not be beneficial for you. It would give you way too much rear lift. That is unless you are going for that "hella raked look".
    -Andrew /forums/images/graemlins/usaflag.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You could put 4 or 6" leaves in the rear if you used the shackle flip (or even a block and stock springs). It will flex better with leaves with less arch but all those parts can get more expensive. 8" springs all around would be cheeper.
  4. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    8" springs up front + 4" shackle flip + 4" springs out back would be ok. super arched lift springs dont flex for chit, so use the shackle flip and less arched springs.
    j
