Is all power wire the same?
Discussion in 'Audio' started by RingMaster4x4, Aug 4, 2003.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Is there a different quality between brands or all they pretty much the same? If there is a difference what are good brands and what should I look for? /forums/images/graemlins/ears.gif /forums/images/graemlins/thinking.gif
    Thanks,
    Todd
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    There is no doubt that companies like Monster Cable, etc have made a small fortune convincing people that their wire is inherently "better" than what you can find elsewhere.
    My take is that it comes down to the AWG (American Wire Gauge) and material (usually high-quality copper conductor) and number of strands of wire in the bundle.
    The AWG is easiest, it's a standard way to specify the safe sizing of wire based on current draw. Every 4 AWG wire will need to be the same for that reason.
    Wire composition (high-purity copper vs. ???) will determine how well the current will flow. Copper is a nice conductor....not as good as pure gold wiring, but certainly cheaper!! /forums/images/graemlins/grin.gif
    Wire strand count may not have much to do with overall safety, etc but you certainly wouldn't want to use solid-core wire in a stereo install (think house wiring!) it will never bend or lay down the way you want. Wires with high strand counts tend to be REALLY flexible, and that can help if you need to snake the wire around all over the place.
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Power wire (12volt) or speaker wire? If you're asking about power wire then any stranded heavy gauge wire will work for a stereo. I find it hard to believe that any one could tell the difference as far as audio is concerned. As long as it doesn't have a lot of resistance/ft. you're okay. Now if you mean speaker wire then that's a different story. Depending on the quality of your system probably won't hear a difference in you car with the road noise. Again, as long as the ohms/ft. is not outragously high and the insulation is good quality then I personally wouldn't worry about it. High power system obviously need heavy gauge, fine stranded wire. Again, with the road noise you won't hear a difference and power loss is very minimal. If this was for a high end home stereo then it's a different story.
  4. rampage
    Mar 20, 2001
    2,261
    73
    You're just a tad faster on the draw aren't you? /forums/images/graemlins/wink.gif
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Thanks Guys! That was waht I was looking for. /forums/images/graemlins/thumb.gif
  6. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Well technically solid cable for the power wire is best. Not at all "user friendly" in a vehicle but solid or even thicker strands will conduct and flow more current with less voltage drop than smaller/stranded cables. The only benefit to having high strand counts is for flexability. If you don't need to twist it all over the place then don't bother looking for high stranded cable.
    I've found for running long power wires from the engine to the rear of our type of vehicles that plain old welding cable provides the best bang for the buck /forums/images/graemlins/thumb.gif You can get 1/0 guage cables for 1/2-1/4 the cost of the fancy brand name cables of equal size.
  7. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    i was under the impression that the higher the strand count was, the higher the current capacity the wire would have.makes sense to me,because the smaller the strands are,the more wire will fit within the same guage,there by running cooler.
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    If you search the net, there is some really "far out" stuff you can read regarding the physics of electron flow, and how electrons travel more easily on the outer "skin" of the wire, not through the middle of it. By that logic, many small strands would give a greater surface area for the electrons to "do their thing".....
    To be honest, I've never met ANYONE who could listen to a stereo and tell me if the power wire was stranded or solid. /forums/images/graemlins/grin.gif
  9. rebelk5frk
    Dec 29, 2001
    815
    Houston, TX
    Small strands can't equal a solid strand of the same guage. With strands you have small amounts of free space in the given area. The smaller the strands, the closer you get to the volume of a solid conductor though.
    Solid cable is best for DC current because DC flows though out the whole conductor. AC is a different story though. The higher in frequency the AC current is the less it penetrates the conductor so stranded wire is better because it provides more surface area for the current to flow through.
    Imagine a water pipe pointing up and down.
    DC is sort of like water flowing in the pipe.
    AC is more like water dripping down the outside of the pipe.
  10. rebelk5frk
    Dec 29, 2001
    815
    Houston, TX
    Called "Skin effect" /forums/images/graemlins/thumb.gif
    It only applies to AC current though. At audio frequencies it isn't very noticable at all. At RF frequencies it can become very noticable the higher you go.
  11. rampage
    Mar 20, 2001
    2,261
    73
    Greg is 100% correct. Electrons flow on the surface of a conductor (physics 101) regardless of DC or AC. For the same gauge wire a stranded wire will conduct more current than a solid wire. If a solid conductor carried more current than wouldn't welding cable and battery cables be made of solid wire???
    People use the water pipe analogy to visualize how electricty flows but in reality that's not how it works.
  12. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    can you imagine trying to weld with solid cable???that would be fun.
  13. rampage
    Mar 20, 2001
    2,261
    73
    Either have I, but there are probably audiophiles out there that claim they can. Of course they have multi-thousand dollar systems with speakers that cost more than 100k. I was just covering my a$$ with that statement in the off chance that someone claimed they could. /forums/images/graemlins/smile.gif But come to think of it, I'm sure everyone hear spend all their money on their truck and couldn't afford such a system. /forums/images/graemlins/crazy.gif
  14. rebelk5frk
    Dec 29, 2001
    815
    Houston, TX
    Uh no they don't....
    Skin effect: Current density, or the density of electrons flowing in a conductor, is uniform across the cross-section of the conductor in DC circuits. But as the frequency of the current increases, the flowing electrons tend to concentrate at the outer surface of the conductor. At 60 Hz, more than 63% of the electrons travel within the outer 1 cm of an aluminum conductor and within the outer .85 cm of a copper conductor. This phenomenon, known as skin effect, reduces the effective cross-section of a conductor, and is a reason for using hollow conductors for some high-ampacity bus work. It's more pronounced at higher frequencies, so harmonic currents can lead to extreme heating of conductors. Where a significant harmonic content is expected, paralleling several smaller conductors is preferred to using one large conductor.
    Ya' might want to check them books again. /forums/images/graemlins/tongue.gif
    Because the current carrying difference is minimal compared to the disadvantages of using solid wire....That's why.
    My point in the first place was one doesn't have to worry about super fine stranded cable that is normally much more expensive than larger stranded cable. Sorry for explaining the reasons. /forums/images/graemlins/rolleyes.gif
  15. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Hey guys.......
    Remember that "far out" stuff I said you could find on the net?
    ......it's HERE now. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
    BTW -> I at least hope that the topic of "skin effect" wasn't covered in Physics 101, I would at least have hoped it was more of a second year topic......maybe Physics 201???
    LOL!
  16. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Actually that was covered in Phy133
  17. rampage
    Mar 20, 2001
    2,261
    73
    You made me go to the attic and unearth my books. I had to break out the air compressor to blow off the 10 yrs of dust on them. /forums/images/graemlins/tongue.gif
    Who was the dork that said that? /forums/images/graemlins/blush.gif
    And yep it was actually physics 201. /forums/images/graemlins/blush.gif
    According to Gauss' Law the when there is no net motion of charge within a conductor the electric field is 0 everywhere inside the conductor and the excess charge is on the surface.
    Obviously any active circuit has a net motion of charge so we aren't dealing with Gauss' Law.
    Current density: Analagous to water flow in a pipe. Sort of, water flows easier at the center because of less resistance. Current doesn't behave the same, it flows easier at the outer edges of the conductor.
    In the future please don't force me break out the books again and prove myself wrong. /forums/images/graemlins/deal.gif
    Permission to return to my idealistic, sheltered life. /forums/images/graemlins/grin.gif
  18. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    This post (and apparent eating-of-crow) is an example of another Physics term.....
    "THICK skin effect"!!!
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  19. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    "It takes a big man to admit when he's wrong...and it takes an even bigger man to laugh at that man..." Jack Handy - SNL "Deep Thoughts"
  20. rampage
    Mar 20, 2001
    2,261
    73
    Thanks, but I'm done with physics /forums/images/graemlins/eek.gif
    FOR SALE: 2 physics books ... CHEAP! Free shipping. /forums/images/graemlins/laugh.gif
