Is an 8 lug wheel the same?
Discussion in 'The Garage' started by puckhead, Aug 10, 2005.
  1. puckhead
    puckhead 1/2 ton status
    Jun 17, 2005
    112
    colorado
    Are all 8 lug wheels the same bolt pattrern?
  2. PDXCHVY
    PDXCHVY Registered Member
    May 18, 2005
    11
    PDX
    Newer Ford Superduties use a metric 8-Bolt pattern. Other wise yeah it's a pretty standard pattern 8x6.5
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no there are 2 different standard 8 lugs.
    8x6.5(GM Dodge, and Ford until 1999)
    Ford went to 8x170mm(I think thats the measurement) in 1999, so those wheels will not fit on anything but a Ford F250 or F350.
  4. puckhead
    Jun 17, 2005
    112
    colorado
    DRAG it is in fact a 99-04 sd thought I had a set of wheels and tires for 125.00
  5. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    at least you checked first.i had to drive six hours to exchange mine. :doah: :laugh: sd's are two coats of paint from fitting. :mad:
  6. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    leave it to ford to change it up and go 8-170mm:mad: dont forget the 7 lug setup thay have:wink1: that was real smart thinking.
