Is an 84' K5 w/ 305 Radiator same as 91' Burbs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigburban383, Mar 14, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Is an 84\' K5 w/ 305 Radiator same as 91\' Burbs?
    My radiator has pin hole leaks, but I got my K5s radiator laying around somewhere, are they the same. Is it smaller? Will it bolt up, well obviously if they are the same.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Is an 84\' K5 w/ 305 Radiator same as 91\' Burbs?
    i would imagine a k5 radiator wouldnt have the same cooling capacity as that of a burban which weighs substantially more, but why the heck not, yank it out from wherever and compare them..
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I think it depends on what originally equipped with. My stock 83 radiator is a 3 core, and even in AZ I rarely see 200 with a/c on. Those are fine for small blocks I think. Big blocks, tow rigs, and very hot motors need the 4 core. /forums/images/graemlins/thumb.gif
  4. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    My stock suburbans radiator seems to work just fine(havent tested when its hot out though), its just that its leaking. I dont really want to put stop leak in ether because its a brand new engine.
