Is axle gear setup hard to learn?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Aug 5, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Are there any books or videos that specialize in showing how to set up gears and rebuild axles. I'd really like to do it myself, I need more knowledge in this area so I don't have to depend on others so much. It's not a daily driver so time isn't an issue, I can afford to screw it up and do it again if need be.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Setting up rears is kinda PIA. You need the tools, time and know how. A book from a local bookstore or online would be your best bet. If you are mechanically inclined and can rebuild a motor or do an axle swap and lift kit you can probably do gears w/ some patsience (sp?) and information.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Richmond gear sales a video. I was never able to find it. One company said it was back ordered and would be a few more weeks. I can't remember what company that was. I paid a friend of a friend to help me out on my first gears. I still don't know enough on it to atempt it on my own..........Dan
    If it ain't broke.......Don't fix it....
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    See if a CK5 member lives sorta close to you who knows gears and axles fairly well and ask them to help you. I'm sure someone would do that because it's just how this group works. That way you learn how to do it right and have someone there to walk you through the process... [​IMG]
    C'mon captain break pedal... quit looking for the parade and drive!! [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
    &lt;&gt;&lt; MARK 1:17 &gt;&lt;&gt;
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Randys Ring and pinion has a pretty good info brochure check out their site. You are going to need some specilized tools (indicator w/base, good inch and foot torque wrench, bearing press, marking cmpd, etc) If you are lacking all or most of these tools and only expect to do one or 2 gearsets in your time you might want to have someone else do it. Setting up gears can be very time consuming to get the correct pattern. I fought a 8.8" a few years ago for an entire day. There is no "Its close enough put the cover on"
    If you are patient and have the tools I would say give it a try.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  6. Cavalry
    Oct 1, 2000
    978
    <a target="_blank" href=http://www.ring-pinion.com/index.html>http://www.ring-pinion.com/index.html</a>
    Luke
    84 K5
  7. I Private Meesaged you (PM). I'll walk you thru it depending on what the unit is. We need more info.[​IMG]
    Damn I need to learn how to use my welder!![​IMG]
    (90 Jimmy 350 TBI, 14 FF/10 bolt, 4.56, tires ??
    (ftn96)
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Randy's Ring and Pinion also has lifetime no questions asked gearsets, so if you screw it up, they buy.
    I would LOVE to learn how to do it, and I will learn one day. I know someone that could teach me, I've just got to give him some cash to change my gears first.
    Tim
