is bias-ply bad?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Aug 20, 2001.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i've heard that radials are better, but i've also heard that bias-plies are better. i'm gettin 33" bias-plied swampers soon and would also like to know if i need different rims for them. some one told me that they need tubes. is that true? if so are tubes bad?
    scott,
    1989 suburban 3/4t 4" lift soon to be rollin on 33s, tbi350
  2. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    I got bias ply tires (Ground Hawgs) and they suck for street driving. just my 2cents
    If you cant go over it...GO THROUGH IT !!! <a target="_blank" href=http://www.CaliforniaK5Krawlers.com>www.CaliforniaK5Krawlers.com</a>
    75 Jimmy 11" lift with 40's
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    there is nothing wrong with bias plys, they dont need tubes, they just dont wear as well on the street. they can also get flat spots from sitting in one place for too long but they go away after two minutes of driving. Im running 36" bias swampers now ahd have no camplaints. i think you can also air bias plys down a few psi more and they have a tougher side wall.
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Bias are better off-road and radial for on-road IMO. I am running 36" Bias Swampers. Now I know what is ment by flat spot. My Blazer sat for 2 weeks and I could feel it the first couple miles.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Here is my two cents worth...... It is a personnal preferance when you say which one is better off-road or not.....It is the way that the tire is built that changes Bias or Radial.....Bias seam to fallow the ruts more than radial...... Some Bias are soft rubber compound and weaar faster and the Bias that are a harder Bias are more bouncy....Bias are normaly harder to keep balanced due to theway the tire wears.....Radials are normally in between the two....
    C'moe
    <font color=black>the blazer is "Back in Black"
  6. scrapmetal
    scrapmetal 1/2 ton status
    Jan 22, 2001
    100
    Rathdrum ,ID
    The real reason for having either is personal preference,but a bias tire has more and stronger bias steel belting inside the tire's skin to make it stronger, I always air mine down to 5 psi when wheeling and have yet to poke a hole in one, a radial is made of steel belting that is woven in a cross hatch pattern making it handle better, and it too is also tubeless, your pretty hard pressed anymore to find anything that still uses a tube except for farm stuff and bicycles, and because of the bias tires belts going from side to side instead of cross woven there able to make them alot bigger, hence the 44". That is the primary reason that radials handle better, less sidewall and more development and research went into it to shut the whiners up back in the seventies, a radial usually only has a two ply sidewall, except for BFG which has three, bias have up to ten ply sidewall, radials are more prone to get poked when wheeling, but yet I've had BFG Mud TA's and Swampers, nothing compares to a Swamper or Bogger, I'd rather not hear and have it ride like [censored], than to be able to hear rides nice, and goes nowhere offroad,, just my opinion
    Never been stuck, just temporarily delayed.
    <a target="_blank" href=http://hometown.aol.com/bcscrapper/myhomepage/index.html>hometown.aol.com/bcscrapper/myhomepage/index.html</a>
  7. muddysub
    Jun 23, 2001
    10,451
    489
    thanks everyone!
    scott,
