Is it busted?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Sep 21, 2000.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    OK this is whats going on, I just moved from the bay area to tucson. the whole way on the freeway my truck was bing jucked around. i think it was my locker. i wopuld hear a loud "CLANK" and my truck would jump to the right. sometimes it started to ratchet like the locker but really loud. could it be the locker disengaging and re-engadging? or could it be something upfront in the steering or front dif?
    From the Grave to eat the Jeeps
  2. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    Re: Is it my locker????
    Make sure you have the correct differential fluid in there. Also, was the locker set up right or did the "true dual man" do it? oh, yeah... what's "jucked"???
    Have been stuck (once) as of 8/12/00
    "(2H) Where's all the mud?.(4H)...(4L)..(4H)... oh crap"
  3. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    I put it in and it is in correctly. it worked fine untile tuesday. and its been in sence july. what is the correct gear lube? i have a limited slip gear lube in there now.
    Sorry jucked is supost to be jerked
  4. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Could be the locker.Have you checked the fluid level?I like to use Lucas gear oil in my drivetrain.It quieted my lockers down.You can get it at Carquest.I would check this first and try it.If you have the same problem pull the cover and make sure there is nothing broken.Brady
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Hey what part of Tucson are you in? We should drive side by side and compare symptoms. Whenever I make a pair of right hand turns into my driveway my truck sounds like the power steering is going bad, but I think its the rear end. I'm near 22nd and Kolb.
    creepin' and crawlin'
    Jim
  6. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i'm on the east side by 22nd and houghten. right be the national monument.
  7. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    the fluid is good checked it alot on the way down here. was getting pretty frustraded. soon as i find a job i'm saving up and getting new gears and a detriot for the front and back. and the full floater kit from ORD or my 12 bolt(maybe).
