Is it even possible to get my truck down to about 4500 pounds???
Discussion in 'The Garage' started by yunit, Nov 12, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Here are my current specs.
    1987 GMC Jimmy
    350 TBI
    TH400
    NP203 & NP205 with ORD Doubler
    High Angle 1 ton shaft's
    Dana 60 front with 5.13s, ARB, 1410 yoke, ARB, plated cover, and hydro-assist
    14 Bolt FF with 5.13's detroit, plated cover, and disc brakes
    Custom Alcan spring's 49" up front & 57's in the rear
    42x15x15 TSL's with steel ARE wagon wheels
    summit plastic bucket seat's
    no bumpres right now
    Other weight items:
    CO2 tank
    full 31 gallon tank of fuel
    tools
    full size spare
    Here is my dilema...
    ...I do not feel like buying a new truck and trailer to tow my trail rig, and I do not want to buy an older truck that will only be used as a tow vehicle to get the truck to the offroad parks in PA, Paragon is 2 hours from my house and Rausche Creek is 3 hours. If I can keep the trailer weight to 6000 lbs, I can tow it with my 92 blazer or just about any half ton truck and my current trailer.
    This blows...anyone want to buy my 92 FS Blazer??? /forums/images/graemlins/confused.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just pull it! Get yourself a good hitch setup. That means equalizer bars, dual cam sway control, load the trailer properly, and keep speed limited to 55 MPH as trailer sway increases with speed.
    If you're not trying to be a speed demon you could probably pull it off.
    Too bad you're not closer, I'd sell ya my C30 for $1500 in a heartbeat...and it already has a Teknosha Prodigy, a class 4 hitch, electric brakes wired in the box AND at the bumper....
  3. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Pete,
    You already know the answer.....even as you type the question!!!
    "light" costs heavy money!! /forums/images/graemlins/grin.gif
    With what you'd spend creating a light truck and trailer, you could EASILY sell the existing tow rig, and buy something more suited to the task...
    Sometimes the answers are boring, but simple. /forums/images/graemlins/deal.gif
  4. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    how much do you waigh now and how much do you care abought comfort? In my old nova to get the waight down I got rid of all the climat control that means heater included door pannels gone any thinking in the cab except gages and a place to put my rear you would be suprized what all that trim waighs carpet in a blazer that at least 25lb if your in a state with no polution get rid of the smog stuff. then their is fiber glass fenders and hoods. get rid of the tale gate have that made as part of the soft top. if you want to get in the engine you could shed 200lb esy buy using aluminum heads, water pump, balencer, headers.
    Just some Idas its alot esyer im my drag car becuse your only in it for 10sec or less. so comfort isnt a major isue.
  5. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    the weight is 5640. Without my tools, jack and a little gas would be around 5500 I would think
    For guessing the weight of my k5 I have been using the UAV it is very close to the way I will be running next summer – the cage and I will have the half cab
    From what I can tell we will almost have the same setup ( but I want your th400 /forums/images/graemlins/wink.gif )
    my trailer is 7000 i am looking to get the ramjetgmc to 6000 allso the trailer is 1000 = 7000
  6. dyeager535
    26,975
    My truck is at 5000lbs, no interior trim, carpet, padding, insulation, etc. Small radiator, No AC, manual trans, 205, 10 bolts, 33x10.5R15's. No additional stuff to add weight I can think of. (no winch, stock bumpers, etc)
    Could lose the top weight and 31" spare tire, but thats about it unless I started ripping off doors, hood, etc.
    Can't recall if the tank was full when I weighed it or not, but that could be potentially 180lbs or so? Probably had half a tank at the time.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i cant believe your guys' rigs weigh so much,
    ive never even weighed a longbed thats been over 3860lbs
    you guys must add ALOT of extra items or something.
    with the weights that your rigs weigh, youre leaving none or hardly any cargo carrying capacity per the GVW rating on door jamb sticker or plate.
    crazy..
    im curious to see what your GVW weight rating minus actual entire rig weight is
    hmm..
  8. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I aint no expert but Id say alot of the weight has to do with them big tires and 1 ton axles /forums/images/graemlins/thumb.gif
  9. ramjet gmc
    Dec 19, 2001
    3,370
    I would say the same thing and if you think abought it have you ever removed a part and put on a weaker part? we add OBA and big bumpers ect what highlift jack is like 40lb
  10. dyeager535
    26,975
    did you read my post? I'm not trying to be a smart ass, but my truck has almost NOTHING in it that isn't factory, although you can consider the 465/205 "non-stock".
    The only thing that adds weight that I've put on is the tires.
    You've got to remember, K5's have more structural metal than the trucks do, as well as a 200 or so lb top, along with (for most of us) a spare tire. Still nowhere near the number you quoted, sounds to me like the scale you use is dead wrong. A 1980's Monte Carlo (RWD mid-size, not FWD) weighs up to 3800lbs from the factory, and no less than 3200.
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The weight issue.
    My point of view is most of the weight added (70%) is below the frame.
    Thick steel wheels (10-25lbs ea),
    big heavy tires (50-90lbs ea)
    axles (300-600 lbs)
    crossover steering (25lbs in tube)
    Longer springs (25-45lbs ea)
    That weight doesn't affect the load carring weight of the axle. The GVW issue is kinda wierd too. A built K5 has all the heavy parts of a 1-ton, including brakes. Sure it has a winch, bumpers, tools, extra parts, spare tire, 2 cast iron t-cases, 4 driveshafts (includes spares), 113ft of steel tubing wrapped round it and the biggest icechest a person could lift, that is fullsize 4wheeling (It's a K5 thing jeeps don't understand). On the other hand a bone stock K5 with top seats carpet etc. weighs in around 4800-5300lbs depending on the year and location (smog, ac, cc, pw, tbi, all add up).
    I'm sure I'm repeating the same stuff a lot of people are saying but i wanted my own spin on it.
    this is all just my $.02
    Thanx
    p.s. I have never weighed my K5 and I'm not so sure I want to.
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    My buddy weighed his k10 short bed at a little over 4000 pounds I believe so that 3800 something sounds wrong to me.
  13. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I had mine down to about 5300 pounds with 1 ton and 40". No doors, top or tailgate a the time. I am in the middle of enougth mods that I think I can get it below 5000. But then I will be adding a cage. I guess we'll see what happens in the end.
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    My '85 K30 with the 4" lift and 35" tires and one gas tank filled up weighed right at 5400 lbs. at the local COOP with me out of the truck. /forums/images/graemlins/thinking.gif
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've still got to get mine weighed, but I'm *hoping* for very low 5k range...
  16. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    My 85 shortbox, no lift. 31" tires 350/700R4/208 on 10 bolts weighed in at 4600 lbs.
  17. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    With me in it my truck weighed in at just a hair over 6000 pounds. And thats with 35 inch radials, aluminum wheels and no AC, tools, gear, etc. Almost 3800 pounds of that is on the front axle. A big bumper, winch, and a cast iron big block will do that. Also, its a longbed.
