is it neccessary to have a pilot bearing/bushing
Discussion in 'The Garage' started by GMC500, Nov 9, 2006.
  1. GMC500
    GMC500 1/2 ton status
    Aug 19, 2005
    203
    Safwa
    hi all
    after inspecting my truck, I found that it only has a throw out bearing and no pilot bearing/bushing
    is it neccessary to have a pilot bearing/bushing ?
    and what is their advantages ?
    truck is a 1986 GMC k15 with SM465
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes it supports the nose of the input shaft in the back of the crankshaft, are you sure that you do not have one that you just missed?
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    Yeah, I'd say it is! It keeps the shaft roating without any wobble, which would kill the input bearing pretty quickly...
  4. GMC500
    Aug 19, 2005
    203
    Safwa
    can you please post a pic of a pilot bearing/bushing installed in the crank
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    This is what the bushing looks like. The hole in it for the tranny input shaft is just a little less than 5/8". The hole that would be in the crank if there was no pilot bushing would be much larger, and you would have bad chatter issues with your clutch/tranny. If you're looking at it wrong, it might look like part of the machining of the crank. Hopefully you're mistaken. No bushing would be very bad.
  6. GMC500
    Aug 19, 2005
    203
    Safwa
    thanks
    I will check it tomorrow before droping the engine
