Is it normal for a 6.2 to NOT blow smoke?
Discussion in '1982-Present GM Diesel' started by Pookster, Feb 22, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    So the 6.2 I picked up, does not blow black smoke! Is there something wrong here???
  2. 82diesel
    82diesel 1/2 ton status
    Jul 2, 2003
    316
    Stockton, CA
    Mine only blows black smoke when I floor it, doing fast take offs.
    Slight white smoke till it warms up.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Under normal driving conditions, your 6.2 should not blow black smoke. AFAIK, there are only a couple of reasons that will cause you to blow black smoke:
    1. A dirty air filter
    2. Too rich of a fuel/air mixture
    Basically, if you start seeing black smoke out of the exhaust, it means that you are putting too much fuel or not enough air through the motor. This can also happen when you temporarily put a lot of load on an otherwise nicely-tuned 6.2. I'm willing to bet that if you put a trailer behind your truck and floored it off the line your exhaust would blow black.
    You should also keep in mind that you are living and driving at or close to sea level. You have the benefit of operating your rig in an atmosphere with a lot of available oxygen in the air. I live at about 3000' feet- I see black smoke behind me every time I'm heavy on the skinny pedal!!!!
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I only get a little smoke at WOT, normal driving I get none.
    Rene
  5. Can Can
    15,552
    136
    Have you noticed a difference when you get to higher elevations? I do know that my 83 ran a lot smoother and seemed to have more power the summer we toured through the Okanagan. Conversely, the ol' 83 used to really suck wind when we used to climb the Highwood Pass(2200 metres!!! /forums/images/graemlins/eek.gif) on a regular basis to get to a campground we liked on the other side of the pass.
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Same here, only blow black when i am really on it.
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I noticed a slight power difference when we were in Utah. Elevation there is about 4000-4500 feet. I don't recall much smoke, but the truck was running pretty light with no top, doors or tailgate.
    I think my gearing really helps, cuz even going through the pass between Price and Provo Utah it seemed to have plenty of power...that pass was about 7800 feet(~2400 metres) IIRC.
    Obviously the more the motor has to work the more it'll smoke. With 4.56 gears it's pretty rare that it has to work hard, especially on the freeway where it's spinning at 2600 rpm. /forums/images/graemlins/yikes.gif
    Rene
  8. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Nope, nothing wrong with that. You're running at the best efficiency you can. You'll probably get really great fuel mileage.
    On the other side, that means you have room to turn up the pump! /forums/images/graemlins/waytogo.gif Mine smokes a lot, especially at full throttle. Of course, I've tweaked my pump a bit. I even get a small puff of black smoke at idle. With my trailer behind, I leave a dual trail of black smoke for all to see! /forums/images/graemlins/rotfl.gif
    Casey
  9. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    LOL your lucky, Mine as the emission guy says blows like a freight train.
