is it ok to use a grade 5 fine thread bolt for the rear caliper brackets?
Discussion in 'The Garage' started by yunit, May 12, 2002.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Just wondering what everyone else is using with their conversion, I cannot seem to find a find thread grade 8 anywhere local.
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I'm not totaly familure with the conversion. So, take this with a grain.
    I assume you are talking about the bracket that mounts to the axle houseing flange and holds the caliper in place. If that is the case, there should be 4 3/8s bolts - correct?
    I would think, a good quality, grade 5 or better bolt would be sufficiant. Keep in mind, rear brakes only appllie about 30% of the brakeing force, even less on a hard stop as the wweight transfers to the front. So, four grade 5 bolts should be plenty.
    Feel better now?/forums/images/icons/smile.gif
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    IMO this is your brakes your talking about. There is no such thing as making do, or settling for. Id say look further for grade 8 (or case hardened). The stronger the better.
    My bud had his caliper bracket welded to the housing, (this was long before anyone made brackets for this application) and twice he ripped the welds loose. (only 1 side gave him a problem for some reason) He had a hell of a time stopping a rig on 44s w/ one caliper spinning around loose.
  4. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    I was typing when you posted yours Twiz, not to step on your toes, but to me when it comes to brakes, more is better.
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Not to pick on Eric...but I agree. Grade 8 fine thread should not be that hard to find, it's worth the extra hassle just for piece of mind. Save the grade 5 and less for door hinges and other non critical parts.
    Rene
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Fair enough,
    It's my opinion that the 4 3/8 grade 5 bolts will be strong enough to hold the plates on rear of the truck. Plates that will only see 30% of the force at yhe most.
    It's not so-much the strength of the bolt, as it is the friction beteween the surfaces that keeps the parts togather. Think about it, If a 8-lug rim was tightend "finger" tight, it would still shear the studs, just as easy as a 6-lugger would.
    The bolts applie the pressure, the pressure appiles fritction, friction holds things in-place.
    I do, how-ever agree with you guys, it's better to build it stronger than you need it to be (grade 8s), but I woudn't think the rear brakes are stressed enough to shear 4 3/8s bolts.
    *quality bolts*
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    But those bolts are in single shear, I wouldn't run less than grade 8.
  8. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    One thing to remember is that a grade 5 fastener will bend before it breaks but a grade 8 will break before it bends.
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    But there is a lot of stress there. I dont know #s as far as shear strenght and such but when I think of the torque applied to the caliper brackets by the leverage of a 38, I am just not so sure that a G5 would make it.
    But honestly what are the odds of a 38 getting sufficent traction and having enuff brake pressure to lock up?
    I understand your point of view of the pressure and friction, and yeah it would probably hold up but I wouldnt want to take a chance given there is something stronger out there. If there was nothing stronger, OK. But as long we are talking brakes, more is better.
    When I have to replace a rivited on spring hanger on a frame rail, there is no way to duplicate the rivits, so I use case hardened bolts, w/ crimp head nuts, no washers to risk squeezing out, THEN I will tack weld the nut to the bolt, tack the bolt head to the hanger, and tack the nut to the frame rail. I can assure you that bad boy aint movin.
  10. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    I agree. BUT what are the odds of a bolt bending between 2 pieces of steel that are machined flat, that have exact size holes. There is no place to bend. That is where shear strength comes in.
  11. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Agreed.
  12. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I also agree with you. The odds of a bolt bending when two pieces are bolted together tight with exact fitting holes is almost a non heard of thing. On the other hand, when referring to different grades of bolts most people are referring to the tensile strength of the bolt not shear strength or torsional strength. I will add, use the same grade bolt that was originally used from the manufacturer.
  13. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Grade 5's would possibly be ok.
    But with my wife and 2 year old son in the truck with me looking down a 500 ft cliff ....
    .... I WANT GRADE 8's !!
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't even like using grade 8! I was thinking of going w/ AN bolts! The factory bolts are short and clamp the backing plate directly onto the axle. When you do the disc swap you have spacers and longer bolts (the brakes have more leverage to try and brake the bolts because they are longer...so it isn't really just single shear but bending and shear). Add to that the fact that the grade 8 stuff you can buy now is mostly made in China and the bolts on your truck were US made...There is no way in hell I would use grade 5!
  15. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    If there is a spacer, than there would be more-bolt to stretch and that means it has a higher ability to provide more clamping force and retain that force longer. (insted of "relaxing")
    Again, My point is:
    It's not the bolt, it's the friction.
    Don't get me wrong though.../forums/images/icons/smile.gif
    I think the grade 5 would be O.K., grade 8 would be better.
  16. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you are going by friction then you should still go w/ grade 8 because you can tighten it down more to create more friction then the grade 5.
  17. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Thanks fellas, grade 8 it is.
  18. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Who woulda guessed thered be so much talk about bolts! /forums/images/icons/tongue.gif
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    BTW, those 14FF flange bolts are 1/2", not 3/8". /forums/images/icons/wink.gif
    Why not give ARP a call and get some of their indestructable bolts? Their bolts are strong enough that they are used as engine fasteners. /forums/images/icons/wink.gif
  20. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Minimum tensile strength of a grade 5 bolt is 105,000 psi vs. 150,000 psi for a grade 8. By those numbers, I would feel safe using grade 5.
    John
