Is It Possible...Does it
Discussion in 'The Garage' started by jones, Apr 1, 2007.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    Is it possible to re-drill 6-lug wheels to be 8-lug by drilling between the holes?
    Does the memory wire on my stereo go to a constant or switched hot?
  2. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    :confused:
    Probably not safe to drill more holes in a wheel... unless you welded some more metal on it, and then it might not balance out... doesn't sound like a good idea, you can get a set of 8lug steel rims for hellacheap.
    The memory wire goes to a constant power source, keeps your stations saved and clock right and whatever else...
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    No way on the wheels
  4. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Hey guys my radio need a constant hot for my memory what wire under the ash would be constant hot?
  5. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    There should be a spot on the fuse box that says batt with a male spade connecter. Plug into that and you should be good.
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Might be a dumb ? but whats a male spade conector?
    PIC?
  7. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Looks like the connecter on a speaker.[​IMG] You will only see the flate piece as the rest of the connector is on the backside of the fuse box.
  8. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    Are these questions for real?:rolleyes:
  9. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    Me and my buddy ran his to the cigarette lighter wire. Is that NOT a good idea??
  10. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Kool thanx that will help. I hate surfing tru channels everytime i want to listen to music after I turn my truck off:D
  11. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Yeah that's why I started it with a :confused: ... was thinking the same thing.
  12. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    Good I was not the only one, I mean both questions are borderline SCARY!
  13. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah seriously, how would the radio keep memory if the power was switched on and off???
  14. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,859
    282
    Truckee, CA
    If your cig lighter works when the truck is off, this will be fine.
  15. jones
    May 17, 2004
    379
    IONIA,MI USA
    YEAH! What of it?:p:
    Question "A" was directed to me by someone else and I gave him an answer then decided to be sure by consulting the Brotherhood.
    Question "B" was my own inquiry because I've never installed a stereo before.Or anyother electronics for that matter. I've had my truck for 4yrs. and the stereo for 3 1/2 of the 4. I just decided to do it this past weekend for a chuckle. Now it's insalled,all is good and just like question "A", I was just being sure.
    Once again....:p:
    :haha: :haha:
    Oh,Thanks for answering the Noob Q's,Guys.
    For future reference: If you have power window wiring under the dash still after you've swapped the guts to manual, the hot wire for the power window switch is a constant hot also,which is where my tach is wired into.
  16. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    Time for me to unsubscribe.
  17. Clod_King
    Jun 7, 2005
    1,094
    Grimsby Ontario
    /\ /\ /\:haha: :haha: :haha: /\ /\ /\
