Is it possible or practical to hook a Jake brake up on a K5?>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silver84k5, Jun 16, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    think it would kinda sound tight, is it possible? or would it be harful or what? anyone know? thx
  2. buick528
    buick528 Registered Member
    May 3, 2002
    55
    montgomery,il
    if its diesel
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    not possible to do it on a gas motor?
  4. Jed
    Jed Registered Member
    Nov 3, 2001
    60
    Alberta, Canada
    Doesn't a Jake brake require a special head/valve train on a diesel that pops the valves open at full compression? (so most of the energy isn't returned upon expansion).
    Perhaps you're thinking of a exhaust brake. Never heard of one of those installed on gasoline engine tho.
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    basically the answer is no hehe, damn that sucks it would be cool as hell
  6. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    what are jake brakes, i saw a sign on the highway that said "no jake brakes" or something similar, and never even heard of it. thx
    Brett
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    "Jacob's Engine Brakes" are a compression brake designed by Jacob for large diesel engines. The smallest engine I know of them fitting is a 11 liter detroit. It has turned into a generic term for that type of engine brake. It works on the same principle as a compression brake on a two stroke motor in a dirt bike.
  8. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    They are making engine brakes for smaller diesels now. You can get a setup for about $400 for your Ford/Dodge/Chevy deisel powerd ride. Something that just came out this year. As far as gas is concerned fat chance.
  9. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    I've seen the ads for those ones that put a flapper valve in the exhaust. Those are just an update on the "blue ox" engine brakes, and they didn't work that well. The "jake" in my pete has 600 hp of braking torque at 2100 rpm. No valve that shuts off part or all the exhaust pipe is going to have that much braking power. /forums/images/icons/wink.gif
  10. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    600hp uh-oh another crazy ass truck driver. Cluck cluck.
  11. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    That's braking hp from the jakes. I've only got a 425 hp cat though it does have 1450 ft lbs of torgue from the same motor. that's from a 14 liter 3406B Kitty Cat motor. /forums/images/icons/cool.gif
  12. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Ahhh I remember the mechanical days.... 2 bad everything is computerized these days. I.ve got 2 of the 3406c's 475 turned up to 550. I wanted the 600's but at the time I would of had to wait 6 months. So I got what I got and must say I like em, 2 bad I'm stuck in the 1st trk century class 500 det. /forums/images/icons/frown.gif
  13. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Yep with a 2100 rpm motor, 2100 in 7th is 38 mph. The perfect gear and speed for a 7% grade. Don't have touch the brakes much if at all. Save the brake for when some cage jumps in front of me. /forums/images/icons/laugh.gif
  14. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    For the lay man, a "jake brake" on a gas motor would pretty much blow the head off the block, a gas motor is not design for that much compression. A diesel motor, because it uses only compression to ignite the air/ fuel charge, is designed for much higher compression ratios. If you want to go diesel, the best "old" style chevy diesel motor was the 1983 J series detroit diesel. Watch out for the old 350 conversions, they were junk as diesel motors, but great to convert back to gas.
  15. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    There was a guy running around here about 15 years ago had a mid 70s 1 ton 2wd long bed that had stuffed a 3208 cat in it with an allison trans too. That baby could pull a trailer. /forums/images/icons/cool.gif
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    How? Isn't that one of those 6' long inlines that are about 4' tall?
  17. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    No the 3208 was used in medium duty trucks. Bigger than a BBC but could be "stuffed" in the engine compartment.
  18. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    3208's were really common in the old medium duty COE Fords - didn't take up much additional room over the standard 332's either.
  19. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Yeah I have this idea of a 1 ton frame and cab. 3208, allison 6 speed, 2.5 ton TC, and axles with rear steer too. Mech injected would run under water as long as the intake and exhaust were plumbed high. /forums/images/icons/laugh.gif
  20. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Please post the pictures when you get it done! /forums/images/icons/wink.gif
    Can I take it for a swim?
