is it possible
Discussion in 'The Garage' started by 1986chevy_rider, Nov 9, 2005.
  1. 1986chevy_rider
    1986chevy_rider Registered Member
    Nov 8, 2005
    97
    fallon nv
    Is it possible to use a np205 behind a 465 tranny that has a 208 sittin behind it already with stretched out chain?
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    It's possible, but you will have to change the shaft on your case or your transmission so they will match. I'm sure it's been discussed, but why doesn't anybody make adapter sleaves? Ya know, 10 spline on one side 28 on the other etc..
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    OR you could just find a NP205 with a 32 spline input & 6 bolt pattern circle and bolt it up. GM made a 32 spline 465/205 from '85-up in the K30s. The only issue is you would need something to pivot the shifter off of...NP205 adapters have the boss and stud.
  4. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    what do you mean?
    Im sorry I dont know to much about chevy 4x4 stuff yet im new and I just know a few general type stuff that ive read off of a discussion type place like here for instance. is there any other options that may be easier for me to do. Ive got about 1700 dollars to do a new used drive train and that has to include 800 dollars worth of new tires. my plan is to go with light 3/4 ton axels and have some long bed 3/4 drive shafts made to fit my short bed k10 that is in the air about 6-8 in not sure thats how i got it. My reason for doin all this is because of all the sterring problems and grinding noises im getting from the t case
  5. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I thought 80 was the last year of the 205, but was a slip yoke?
  6. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    Good luck finding a 205 with the round bolt pattern and the input shaft that matches the tranny. I looked two years and found nothing you could buy it but it would cost a good bit not worth it if ya ask me I just bought a 465/205 combo from a k30 and put the whole thing in. it was cheeper and way easier to find
  7. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Why not just buy another 208? I'm pretty sure there is one in the for sale section.
  8. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    are 208 worth it
    Are they worth the troble. ive been told that they arnt.
  9. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    The 208's are not bad, the have a good low range, they are lightweight and unless you plan on making big torque numbers I would not worry about having a 208. I have one in my beater Blazer and I wheel it pretty hard and so far no trouble at all. It is more likely that you will break u-joints and driveshafts before you break your 208.
  10. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Got two 700R4's, a 208 & I've got a NP241 - with a speedo cable. Pick your poison... NH and hate to ship big stuff. You can put a SYE kit on the 241 so you don't have the slip yoke. :wink1:
    GMC Graemlin
  11. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    where is it that you live.
    How much does that 241 cost and really how much does the shipping cost from there to here. and can you explain the SYE stuff to me thanks
  12. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    well right now
    My engine is puttin out about 350 HP and 400 ft pounds of torque. im not sure if that is alot for 4 wheelin but im only plannin on goin up.
  13. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    You can email me about the t-case at papasmurf1990@hardcore4x4.com
    Check the tech section for the SYE stuff.
    GMC Graemlin
  14. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Nope, available thru '91. :thumb:
