Is it possible????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Dec 11, 2001.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Could a 700R4 last 186,000 miles without being rebuilt in my truck?? I bought this thing in September and I don't know if the tranny has been rebuilt. Also, the U-joints are the ORIGINALS! Except for the front driveshaft joints.
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Most definately! How do you know it has a shift kit in it and not know if its been rebuilt unless you had it installed? If the previous owner did that I bet it was during a rebuild. Still very likely could be the original I have seen them last 200,000+ under good care conditions
    Granny LOW and let her GO!!
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  3. dyeager535
    26,980
    Sure it can. But a painted torque converter or transmission pan/case will typically indicate a rebuild.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. EZdoesit
    EZdoesit Registered Member
    Oct 11, 2001
    33
    Minnesota
    I would bet it could last that long, mine has 152000 miles on it and it's totally fine.
  5. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    I installed the shift kit. Nothing is painted on it. The guy I took my tranny to didn't paint anything, he just cleaned it off. If the Torque Converter was painted, all you could really say is it has a new one. I just want to know because I'm going to be taking this thing on a trip to Colorado next summer while towing a 1,000 trailer and 88 Suzuki Samurai for rock-crawling tagging along on it.
