Is it time for a rebuild? part 2
Discussion in 'The Garage' started by NEK5, Dec 8, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Alright guys..It`s been previously stated that I`ve had some issues with my motor, mainly that it smokes alot and burns a good amount of oil. So far I`ve done a few things. 1) found out PCV port was clogged on the TB 2) pulled the TB off, cleaned it up, then reinstalled. 3) I then replaced the PCV valve, along with giving it an oil change, and as soon as i pull out of my driveway to take it for a spin, I left a nice cloud of smoke infront of my house, and again every time I got on the gas, or left a stop sign.
    I`ve yet to do a compression or leak down test.
    As I was told by ryoken to check my blowby from the breather, but I`m not sure how to describe it..like how much is too much etc..
    Any suggestions, advice, etc. you want to add, feel free...
    If you think it`s obvious I need a rebuild, maybe throw out an idea of what I should do, ie get a rebuild, get a crate (any specifics, under $2k), etc....
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Do the compression and leak down tests before you get too involved with replacing this thing.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    do a compression test. its a good place to start. If you can do the labor on a motor swap, then $2K gets you a nice motor. I had one built for $1600 that puts out 400 lb/ft. I did a lot of work myself. I did all the engine disassembly.
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Well, I`ll be able to get a good amount of help with the swap if need be. If thats the way things go, I think 2k will be my limit, maybe 2500.
    I`ll look into get a CT done soon, hopefully my friends dads up for it:eek1:
  5. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    you can do it yourself it just takes longer.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok, yesterday when i was out driving i got the noise again. Sounded more a like a knock, and it did it 3 times in a row, and when i heard it, i looked in my rear view mirror and saw some pretty smoke pouring out of the exhaust:eek1:
  7. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    Merry christmas honey, I spent all the kids present money on a new small block.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    DO THE FREAKING LEAKDOWN TEST ALREADY!
  9. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    If you keep doing the same thing and expect a different result then, you sir are stupid. Diagnose it with tools, not a keyboard. time to get your hands dirty.
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    No, I don`t think repeating my self many times is going to tell me anything different. I do plan on a leak down and compression test as soon as i get the time/tools/help. I just got done moving houses, so its been a little busy around here.
    As soon as i do both tests, I`ll post up any and all results....I think its not going to be the results i`m looking for, if so, i may have a lead on a motor with the same amount of miles on it, but it doesnt smoke and it runs strong, according to muddybuddy:D :rolleyes:
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Since it`s already obvious I`m burning oil, would you rather a leakdown test or a compression test? or will i pretty much get the same results?
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the leakdown test will tell you more information.
    it will tell you if and how much compression you're losing, as well as where you're losing it.
  13. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    as far as simplicity goes, the compression test just tells me that the certain valve is bad, right? not just rings?
    also for a leakdown test, what do i need to buy, the fitting, a certain kind of guage?
  14. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    http://www.type2.com/library/engineg/leaktst.htm
    check this out. it is a simple explaination. a compression test is easier, but a leak down will tell you more. a compression test will tell you if you have a bad cylinder. if you do a compression test and gets some real low numbers on 1 or more cylinders then its obvious something is wrong. if they are all close to the same then a leakdown is the next step.
  15. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    thank you sir, that`s what I was thinking...
    Since I know I can readily get the compression tester, I think I`ll do that first...then if the numbers aren`t too bad, then a leakdown test will follow...
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a compression test will tell you NOTHING but the fact that there is low compression in a certain cylinder.
    a leakdown tester...
