Is Mobile Authority a good brand?
Discussion in 'Audio' started by Blazer79, Feb 25, 2001.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    As you may remember, I wanted to connect three amps from one RCA output (my portable minidisc player). I tried using Y-cables but that only blows fuses.
    Now I bidded on a Mobile Authority 5 channel crossover. Is this a good brand? Here are the specs:
    -- 5-Way Electronic Crossover Network
    -- DC to DC Converter power supply
    -- Subwoofer Input Switch on/off
    -- Stereo/Mono Selector Switch on sub output
    -- Low Pass Crossover Frequency: 50, 80, 100, 200 Hz
    -- Rear Low Pass Frequencies: 100, 250, 400, 500 Hz
    -- Rear High Pass Frequencies: 80, 100, 120, 180 Hz
    -- Front Band Pass Frequencies: flat or (500-1.6kHz)
    -- Front High Pass Frequencies: 1, 2.5, 3.5, 5 kHz
    -- Adjustable Output Levels (sub, rear, Front)
    -- Gold Plated RCA Input/Output connectors and power terminal screws
    -- Slope rate: 12db/octave
    -- LED Power on indicator
    -- Remote Turn on
    Can someone explain what do they mean by "Front Band Pass Frequencies"?
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I imagine front bandpass means that it will apply a low pass and high pass x-over to the same output. This would be used for something like a midrange speaker. And sorry, but the brand doesn't have a really great reputation. If the price sounds too good to be true, it probably is.
    '73 K5
    Chevy good...Ford bad
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    MOBILE AUTHORITY IS IN THE SAME CLASS AS BOSS, THUMP, AND LEGASY. IT'S A CHEAPER NAME BRAND FOR A RESON.
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I have found that just because they are cheap doesn't mean it is junk. I am on a limited budget on my projects and run a cheap Power Acoustic amp, and 2 cheapo 10" subs, and they have been working great for 2 years now. No problems whatsoever, just make sure it is installed right. And for me I can't see spending loads of money on stereo equipment when I still need a Dana 60 for my truck /forums/images/icons/smile.gif
    My brother has spent the cash for expensive stereo equipment and has had 6 subs , 3 amps, 3 stereo decks, and 2 6x9's stolen to my 0 items stolen. And I never thought his high dollars systems sounded that much better anyways.
