Is my 203 a "part-time" TC?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBen, Feb 25, 2003.
  1. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Is my 203 a \"part-time\" TC?
    I'm trying to get rid of my TH350/NP203, and may be able to help Dunerunner and his buddy out if my 203 is part-time...
    If I am thinking straight, the 203 never powered only the rear axle..... allow me to elaborate:
    If I twist the rear output yoke, the tranny input spins, but the front yoke does not.
    Being wary of the differential effect, I also tried holding the rear output yoke and spinning the front yoke. The tranny input DID NOT spin.
    This indicates to me that the case has a part-time kit installed (front output totally disengaged from the tranny input).... is this correct?
    Additional hint: The front hubs were converted to manual lock... the only reason I can come up with for this was a part-time kit.
    Thanks,
    -Ben
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Re: Is my 203 a \"part-time\" TC?
    the best way to tell is unlock your front hubs and put the t-case one position up from all the way back(4-hi) if you give it gas and the truck goes nowhere, you are full time, if it goes, you are part time.
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    do you have to have it in loc to make it move? my dodge when i had the front shaft out had to be locked to move at all, you could have one in there, lock the hubs, put it in hi, and try to do a break stand. /forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes it would have to be in one of the two loc positions to go anywhere with a shaft removed
  5. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Sorry guys, I should have told you more.....
    The T-Case is out of the truck and laying on my garage floor! /forums/images/graemlins/shocked.gif
    The guy I bought it from claimed it had just been rebuilt, and the symptoms I described above made me think it has a part-time kit in it......
    Let me know what you think,
    -Ben
  6. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    you could take the rear housing off and take a look, if it still has the spider gears then it hasnt been converted, but thats a bunch of work, removing the housing and tailshaft
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    -Ben
    Based on your description above I would say it's a part time converted case.
