Is my engine toast
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Sep 19, 2002.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I posted about valve guides and someone brought up the point that the engine may be on its way it. Its an 89 350 TBI with 124k, runs real strong, just smokes on start up after its sat for a few hours. Smokes when the truck shifts at high rpms, and when you turn real hard while on the gas. Sounds like a top end problem to me, am I right?
    AW
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Black smoke or blue smoke?
  3. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    blue
  4. dyeager535
    26,980
    Even if it smokes, it doesn't mean its on its way out. It just means its worn, and could stand a rebuild IMO.
    The more wear you get, the more the clearances get excessive, the more problems you will have later on. If the crank starts slipping around in the bearings more, you may have to have it turned, whereas if it was pulled before the bearings got real loose, it may just need a polish.
    124K isn't a whole lot, and startup smoking is just a sign of worn valve seals due to the crappy stock seals. The engine smoke at higher RPM's I'd be more concerned about.
    If you are contemplating a head/TPI swap, it seems kind of pointless to spend time and money on valve seals, when you are just planning on replacing heads anyway. I'm in the same boat, my distributor needs a bit more work, but I'm not spending time and money on it, when the TPI distributor is going to replace the distributor in there now anyways.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Sounds like valve seals. You can put some umbrella seals on it and buy a lot of time.
  6. k5_beater
    k5_beater Registered Member
    Jun 11, 2002
    35
    New Jersey (Armpit)
    definatly valve seals. i currently have the same problem and it is only going to get worse. check and see if you have and oil on any spark plugs.
  7. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I just replaced the spark plugs and they were toast original 124k mile spark plugs. But they weren't carboned up or anything. Im worried it may need new seats too. Thats why I was contemplating the head swap. Other than disassembly, is there a way to tell if the seats need work?
    AW
  8. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    Don't waste your time if you are only going to replace the seals. Mine have been leaking for about 15 years. Some times it smokes sometimes it doesn't. It is only embarassing if it smoke really bad.
    If you are really worried, do a compression check on all cylinders. That will tell you if you need to rebuild or not. You could also try a top engine cleaner to clean out any carbon.
  9. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    These particular engines came from the factory with poor valve seals. It is extremely common an all of the throttle body injected engines until '95 to smoke on startup and consume 1-3 quarts oil expecially when the clock turns past 100k. Have seen many run past 200,000 smoking all the way. The bottom end is probably fine. Have a reputable shop rebuild the heads and run it.
