Is my front diff yoke messed up?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by EZdoesit, Dec 10, 2001.
  1. EZdoesit
    EZdoesit Registered Member
    Oct 11, 2001
    33
    Minnesota
    Ok, I just replaced the front u-joint on my front driveshaft about a month ago, and when I was putting the shaft back in the truck I found that the driveshaft yoke on the front diff only had a locating tab on one side to hold the u-joint cap in place, the other side was just smooth, I didn't have time to worry about it then so I just bolted the clamps on and it seemed to be holding the cap in place.
    I was using 4 wheel drive this last weekend and it was smooth at first and then after a while I started getting a bad vibration above 15-20 mph, I took a look under the truck when I got home and I found that the u-joint cap on the smooth side of the yoke had moved out a little bit and I could wiggle the shaft about 1/8th inch or so.
    do I need to replace this yoke to fix this or am I missing something?
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    If my memory serves me correctly I had the tab on both sides of my 10 bolt. Which axle do you have?
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Well the caps have to be held in by something. If there is no snap ring, then there has to be a tab. All of the yokes I have ever seen have had a tab on both sides. Maybe a former owner threw a driveshaft and just did a quick fix?
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
  4. EZdoesit
    Oct 11, 2001
    33
    Minnesota
    that's kind of what I was thinking, that they just did a quick fix to get by before, I have a feeling the missing tab is why the last u-joint blew out on me. Also, it is the stock 10 bolt front axle.
