is my np 208 bad?
Discussion in 'The Garage' started by sunnyc123abc, Jul 11, 2005.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    I have a 84 chevy blazer with an np 208. I am a newbie with offroading and trying to learn more everyday. When i put it into 4lo and try to climb up a small hill it is fine till when i get to the top and give it some gas to go over it. it makes a kind of grinding noise. i can't tell where is coming from but i think its the transfer case or the axle..by the way its a 10bolt. Can you please tell me what is wrong and help me out. thanx
  2. jrpeebles
    jrpeebles Registered Member
    Jan 19, 2005
    40
    North Hollywood Ca.
    The most common problem associated with 208's is that the chain wears out and slaps against the aluminum housing, causing it to crack.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive had more problem with syncros wearing out before the chain does.
    make sure the linkage is adjusted right, it may be trying to pop out.
  4. chevyk5blazer666
    chevyk5blazer666 Registered Member
    Jul 6, 2005
    44
    N.J.
    that happened 2 my blazer and a real quick fix is a bungy cord to hold the shifter tight
  5. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    check your front slip yoke in the shaft for move ment. it might be geting striped it hapend to my '82 1/2 way up a hill not good.
  6. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    Cool.. thanks for the replys, very helpful. I ll check it out tomorrow.
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    My 81 kept popping out of 4-lo and wouldn't even stay in 4-hi. I adjusted the linkage and now both work flawlessly.
  8. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    It;s jumping out of gear. Check and see it the transmission mount (on the transfer case adapter) is intact and bolted in. These can go bad and let the drivetrain walk around pulling it out of gear.
