Is my power steering pump bad?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DERBINATOR, Jul 18, 2002.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    Well here is the deal. My power steering was working fine until I did my crossover. Now its not there. When I rev the motor I get some power but at idle theres nothing. I assume its the pump but why would it go bad just because I changed steering boxes???
  2. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Did you bleed the system enough? I had to bleed mine alot when I changed my hoses..
  3. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    I think I did. What is the right way to bleed the system?
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I had a similar situation arise when I did my crossover setup as well. Mine turned out to be the piston thingy in the pump getting stuck and not letting enough fluid past...I took the thing apart (just take the large nut off and the piston should pop out along with a spring)...if it doesn't pop out, it's probably stuck down there...it happened twice more after that as well...weird. As far as bleeding, I was told just to lift the front tires off teh ground, crank the wheel back and forth a bunch of times with the cap open and then go drive it! Hope you get it figured out, I know how frustrating it was for me!
  5. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    Thanks. I did take the piston apart and everything seemed alright. Looked clean and the spring pushed it out. I'll try bleeding it again. I wasn't doing it with the cap off. The motor should be running while turning back and forth right? One other thing I'm unsure with is when the belt is off and the pulley is turned by hand should there be any drag or should it freewheel??? or am I just reaching here
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I'd certainly try taking the output tube off the pump and see if it is still pumping. If you got no steering assist, some part of the hydro aint working (Sorry for stating the obvious).
  7. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    I know its a hydro problem but is the pump bad if there is no assisst at idle but there is at higher rpms.
  8. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    The best way I have found to bleed is to put the front axle on jack stands so the wheels are just off the ground then turn the steering wheel lock-to-lock. The first couple times check the fluid level, the more you bleed the less you will have to add. I have done it with the cap on and off, didn't notice a difference, the cap should have an air vent.
    FYI: I added a small oil cooler to my power steering return line and it never gets too hot when I'm 4wheeling.
  9. 73blazerUSMC
    73blazerUSMC Registered Member
    Jan 29, 2002
    43
    South CA
    there might not really be any steering assist as the truck moves faster the whell will become easier my 2 c
    ps: sorry if im stating the obvious
