Is my rear a locking Diff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Peeetah, Oct 4, 2000.
  1. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    I have an 81 Jimmy with a 12 bolt diff. The build sheet says it came with a locking diff. How can i make sure it's still on the truck?
  2. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    lift the rear and spin the one of the wheels. if they both spin in the same direction you got a locking diff.
    go heavy or go home
  3. Does that go for the front also? When I'm in 4WD, the truck pulls hard right then hard left then...well you get the picture. Does this mean I have one in the front? I guess I could drain and pull the dif cover off, but even then I would not know what I am looking for
    '84 K5
    Chevy in my blood.
  4. rich'90
    Feb 27, 2000
    159
    Savannah, GA
    I suppose it would work in the front also. The principal is the same, but I don't have a locker in the front so I cannot be positive.
    go heavy or go home
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you have the factory installed Gov-Lok, when you spin one side (with both rear tires off the ground) the other will spin in the opposite direction just like a standard open diff. If both rear tires do spin the same direction then you definitely have some type of locking differential.
