is my spindles shot? pics
Discussion in 'The Garage' started by Zeitler, May 8, 2005.
  1. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    my mind says this kingpin is dead
    Edit : updated pic
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    you could prolly get a speedy sleeve on those spindles but that king pin is dead!
  3. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    Who'd you bury?
    Looks like a shallow grave next to the K5! :blush:
    I'd say the spindle is useable,I've had worse that a bearing spun on,and I still got away with using it,yours dont look too bad...but I dont see any kingpins in the pictures- :confused: --what kingpin??... :crazy:
  4. Zeitler
    Feb 22, 2005
    99
    yea the yard is really small ..
    one more:
  5. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    If it hasn't worn a crove just take a punch and swell the metal.
  6. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    2nd pic is kingpin, yeah it's dead!
  7. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I don't see a kingpin?
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Could someone clarify:
    a. what a kingpin is.
    b. draw little arrows pointing to where the kingpin is.
    (Im not being sarcastic, im really confused). I thought the pictures were referring to a scored/worn out outer that may not be able to seat a new bearing.
  9. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    sh#t sorry it was the 3rd pic not 2nd :doah: it sits on top of the "C' at end of axle tube. the cone shaped part that it pitted. i have heard the d60 is not a true kingpin setup not sure why, never worked them till the 60. but the cone shaped part is the "kingpin" in question.
  10. dave_90_blazer
    Jan 1, 2004
    688
    third pic is an aerial view of a truck?
  11. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    not sure what you are seeing but i don't see no truck just spindles and a kingpin!
  12. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    lol I see it to, first 2 pics are of the spindal and the last is a overhead shot of a truck with a light bar on its top. :confused:
  13. dave_90_blazer
    Jan 1, 2004
    688
    same here
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'm guessing by your location that a replacement would be hard to come by. I would clean it up with some very fine sandpaper and run it.
  15. Zeitler
    Feb 22, 2005
    99
  16. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    even if you had a really bad spun bearing that ground a .03 or even a little deeper, as long as the heat from the damage didnt fatigue the spindle it is repairable. we do hitech super hard coatings at the shop I work at. I fixed both my d60 spindles cause they had spun a bit. the coating we used is so hard it will never wear out. boeing aircraft did a 6 month distructive test on this coating, they subjected it to all kinds of acids, corosive chemicalls, salt baths, extreem cold, and heat grit blasting, you name it they threw it at it. they could not find any measureable wear down to the ten thousanth of an inch, thats .0001 for those who dont know. the coating expert here said he didnt need to put that particular coating on my spindals, but since they were spraying a job with that coating at the time he told the sprayer do spray the spindals too. reguler steel or stainless steel would have been fine to use for my aplication.
  17. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    Uh, maybe if you kept the greased and adjusted you wouldn't need to know that.
  18. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    maybe he just bought it!! :screwy: i recently inherited the same issues from a previous owner.
