Is my Water Pump crapping out?
Discussion in 'The Garage' started by equalizer, Oct 27, 2003.
  1. equalizer
    equalizer Registered Member
    Oct 13, 2003
    35
    Currently in Northern Alberta. Soon to be heading
    I'm driving and notice my theromstat is maxed out (i m mean, totally to the right). I had also been noticing for the last week that there is a hidious squeal coming from the engine when I accelarate quickly. So after that, and todays themo deal, I decided to check the manual....I've come to the conclusion that its the water pump, but should I replace the themostat first and flush the rad before I start to replace the water pump....Or, is it the water pump for sure. Seems to me that replacing the pump isn't a big deal, but, of course, I don't want to do it if it dones't need to be done...
    Thanks in advance
    Marc
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    what does the coolant look like? what year and engine? a little more info could possibly help..but id say if you dont know how old the waterpump is, you could replace it for safetys sake..
  3. equalizer
    Oct 13, 2003
    35
    Yes Yes,the engine, its a 305 (in a 72 K5). Right now I m actually trying to assertain more about the engine (codes, date manufactured) when I have to inevitably order a new pump. Your probably right, replace it anyway as I' m almost positive its never been done before....
    Marc
  4. Confedneck
    Nov 1, 2002
    5,236
    try taking the belt off, and spin the waterpump by hand, if it makes a lot of noise...time to replace it..
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    usually that noise you are hearing is the death wine of the bearing, next the seal will go and it will start leaking Coolant.... /forums/images/graemlins/frown.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Quickly followed by failure of the bearing and the fan eating the radiator which is (pocketbook willing) quickly followed by replacement of radiator, fan, and water pump when all that was needed was a $16 water pump.
