Is Same Starter Used for both Manual and Auto?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Jun 24, 2001.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Just converted my K5 to manual with a sm465. I had a th350. My question is, is the starter going to work for the manual setup I now have?
    Crawlin the rocks with my K5
    <A target="_blank" HREF=http://www.rockreadyk5.com>http://www.rockreadyk5.com</A>
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have always wondered the same thing too.
    I have put on 5 new starters on my 85 K30 in the past 5 years and everytime I went to get a new one, the parts man ask me if it was an automatic or standard. So, I guess they are different, but dont know how.
    Word of advice: Get a lifetime warranty starter. Those rebuilt ones suck and dont last. I replaced it the fifth time with a lifetime starter and never had problems again.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  3. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I always thought they were the same until my friends went out on his '68 camaro (auto.). I had one off of my Elco (4sp)that I wasnt using so I said he could use it. He put it on and it kinda grinded. He went to get a new one and the guy said it didnt work cause it was for a manual. I dont know how either, as long as both starters are for the same amount of teeth on the flywheel it should work, right? Hmmmmmm.......
  4. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    I just swaped a motor and cab off of a Automatic on to a frame with a manual in it. We ust the starter off a 2wd turbo 350 and put it on the motor bolted up to a sm465. Works Great. Just like normal.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    As long as your flywheel and flexplate have the same number of teeth it should work fine.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  6. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    GM has only used 2 different setups on all small-blocks, big-blocks and 90 degree V6 engines. Either 14" diameter, 168-tooth flywheel or 12-3/4", 153-tooth flywheel.
    The large diameter flywheel uses a starter with 2 offset (diagonal) mounting bolt holes. The small diameter wheel uses a starter with 2 mounting holes that are parallel to the back of the block.
    Most engine blocks are drilled for either pattern, so only difference is the flywheel diameter. Many aftermarket performance starters have dual pattern mounting holes that can be used with either starter.
    If you are using a stock replacement or remanufactured starter, just make sure that you have the proper one for your flywheel or flexplate, based on diameter and number of teeth.
    Other than that, the only other issues are clearance for headers, if you have them, and making sure that you properly shim the starter for the correct engagement. Otherwise, you can chew-up the teeth on your flywheel/flexplate, which is a real pain to replace.
    So, in your particular situation, you will only have to change starters if your new flywheel is a different diameter than your old flexplate.
    502Burban
    <A target="_blank" HREF=http://community.webshots.com/user/robbrj>http://community.webshots.com/user/robbrj</A>
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    One of the "original" differences were that the std. starter had a steel nosecone to make it stronger. In the early days of High compression, A std trans could "kick back" when started. So GM used steel nose cones because the aluminum ones would break off and leave the starter hangin by the wires. with the lower compression engines of today, this is less likely to happen.
    your right. I don't understand the jeep thing!
  8. Waxer
    1,857
    Long Beach, CA.
    Ok got the new motor started today and the starter worked fine. It grinded a lot at first, then I shimmed it and the grind went away. Works like a charm now. Thanks guys
