Is the 84 blazer deisel and gas blazers the same as far as the body mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80Jimmy, Apr 22, 2003.
  1. 80Jimmy
    80Jimmy Registered Member
    64
    Idaho
    I am planning on lifting my 84 6.2 diesel blazer. I was looking at lift kits and I noticed on several websites they say that the body lift kit wont fit deisel models. I thought they were the same. If not what is different about them and were can i get a body lift kit for the deisel?
  2. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I have always wondered the same thing. I had an 82 Suburban diesel and noticed that it never included diesels. The only thing I could think of is maybe they have some extra motor related stuff that would be in the way if you did a body lift. Anyone got any insight to this mystery?
  3. 82GR8WHITE
    82GR8WHITE Registered Member
    Apr 4, 2003
    15
    Corpus Christi Texas
    I have been looking into this as well and have the same question. The only thing I can think of is the hose going to the hydraboost might not be long enough and is not included in the kit. But you could get a longer hose from NAPA.
  4. 80Jimmy
    64
    Idaho
    So I should be allright since I am converting my blazer to gas correct?
  5. 82GR8WHITE
    Apr 4, 2003
    15
    Have you found out the difference? In your swap are you keeping the hydroboost or going to vaccuum assist?
  6. dyeager535
    26,980
    Re: Is the 84 blazer deisel and gas blazers the same as far as the body mou
    FWIW, all '85/86 C/K5 body mounts are identical. So if the companies say the body lift won't work on diesels, it has to be something else.
    Probably the lines from the hydroboost "master cylinder" won't reach or something.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Body lifts won't work on new Diesels because of the intercooler piping. If you can make that work, a body lift will work fine.
    The orange Dodge on the front cover of Four Wheeler magazine this month has a 3" body on it. They must have made it work.
  8. dyeager535
    26,980
    When did they start intercooling them? Some GM turbo cars didn't start until 1986 (GN) I never thought about that for the diesels, but were the 6.2's even intercooled?
  9. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Unless it's aftermarket, it ain't got a intercooler. Very few Banks Turbos were optioned on Blazers. Even the ones with the Banks tubos were not intercooled.
  10. JDBlazer454
    Feb 27, 2002
    951
    Vancouver, Wa
    My 6.2 wasn't turbo'd let alone intercooled. I had the plain jane gutless version. The only thing I could think of is the hydroboost and possibly the fuel pump or tank.
