Is the front shaft supposed to move when I'm driving???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chaka73, Apr 13, 2000.
  1. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    Is the front shaft supposed to move when I\'m driving???
    Hey guys is the front drive shaft supposed to move when I'm driving, not off-roading but on the street just regular driving, I just installed the rear shaft back on there and I noticed that the drive shaft in the front was also moving but only when i'm going over 10 mph is this normal??? I did put the transfer case in neutral but it still moves is this normal or is something wrong with the transfer case thanks guys.
    keep blazin !!!
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Re: Is the front shaft supposed to move when I\'m driving???
    Need more info, what t-case, locking hubs,exc?
    C'moe
    <font color=black>the blazer is "Back in Black"
  3. chaka73
    377
    Southern California
    sorry, the transfer case I think it's a 203 not sure but it's the original in my 73, dana 44 front and 12 bolt rear the locking hubs are manual also the originals hope that helps.
    keep blazin !!!
  4. colorado_emt
    colorado_emt Registered Member
    Mar 12, 2000
    84
    Arvada,CO
    If you have a np203 then it will, unless you have a part time conversion, then it shouldn't, but if you forget to unlock you hubs(assuming you have manuals) it'll turn your sahft.
    <font color=red>Chris</font color=red>
    <font color=blue>79 K-5</font color=blue>
    [​IMG]<font color=blue>EMS RULES</font color=blue>[​IMG]
  5. chaka73
    377
    Southern California
    No I always remember to unlock the hubs after wheelin.
    keep blazin !!!
  6. colorado_emt
    Mar 12, 2000
    84
    Arvada,CO
    Yea figured so just thought i'd put that in there. If it is a 203 and it turns i'd have to say not part time conversion.
  7. colorado_emt
    Mar 12, 2000
    84
    Arvada,CO
    Hey what ya know i made newbie!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    ¡Hey tocayo!
    ¿Qué dice en la palanca del transfer case? If it's LO LOC-LO-N-HI-HI LOC, then it's a NP203 full time transfer case, and should have no hubs at all. The only reason someone would install manual hubs is if they installed a part time kit. If that's the case then you are probably running in 4wd mode with the manual hubs unlocked, which would make your front driveshaft turn. You should then find out which part time kit you have installed and maybe someone will tell you in which position your lever should be in the 2wd position.
    If it were an unconverted NP203 and you have manual locking hubs (which makes no sense), and you unlock the hubs, the front driveshaft would spin but the Blazer wouldn't move.
    Or it may be as simple as the front driveshaft being actually turned by small friction between the parts even if you are in 2wd and everything's fine.
    Buena suerte
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  9. cocky
    cocky Registered Member
    Feb 21, 2000
    88
    Northern Colorado
    I have a 70 k5 with a np205 t-case and d44 axle. My front driveshaft turns slowly while i go down the road(even in 2 wheel drive). I have noticed some other blazers that do this too.
    Richard
    1970 k5 Blazer
    Don't stand in front of a train naked
  10. cityfarmer2
    cityfarmer2 Guest
    You guys are Brave to be under a moving vehicle. Who was driving the wife.... Were not worthy!!! HEHEHE. Sorry couldn't resist. OPS Normal... Gary....
  11. Grim-Reaper
    7,385
    Atlanta
    Its not uncomon. What is happening is there is a fluid or grease drive going on. The fluid in the case may be causing enough drag to rotate the front output or it could be coming from some drag at the locking hubs. If your sure you have a part time 203 then don't worry about it. Since it doesn't happen from a dead stop (comment about 10mph) then I would guess that it is converted.
    To the rest...he gave details...concider them before giving weird advice like "you may not be converted".
    C'Moe gets a star for asking for more information. And the guy with the 72 cocky, gets one also for being observant.
    Blazer 79 gets 2 stars and a [​IMG] he picked up on it and gave some great information.
    Class dismissed :)
    See now all your praise has me all cocky and sh!t. haha
    Diging it in the dirt with my K5's
    Grim-Reaper
  12. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Mine will also rotae slowly going down the road.
    On road trips after it all heats up the rotation stops all to gether.
    I can see the front drive shaft thru the xfer case shifter boot.
    I think its a good thing that it turns cuz just means all is well and no binding!!
    Rock ON![​IMG] 72 K5 [​IMG]
  13. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    you didnt really say how fast the shaft was spinning. If it seems to be turning at the full speed of the rest of the driveline, then something is engaged. Crawl under your truck and grab that driveshaft and try to turn it. Im not sure about a 203, but with a 205 it should turn freely. Unless the hubs are locked, or the t-case is engaged. If it doesnt turn, you can isolate which end is engaged by jacking the front tires off the ground and turning them. If they turn, the hubs are engaged, if they wont turn, the case is in 4wd.
    If the shaft does turn freely when you crawl under, dont worry about it. Mine does that all the time, but I can reach thru the floor and stop it very easily which means nothing is engaged.
    Good Luck
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  14. chaka73
    377
    Southern California
    Hey guys I dont really know for sure what t-case I have I've only had the truck for about 3 months or so and I really havent been paying alot of attention to the t-case or if I have a part time kit which now I'm thinking that I might, my friend has a 73 also with the original t-case but now I remember that he has no hubs on his rig, so I should have a part time kit which one I dont know, how do I find out?
    keep blazin !!!
  15. Blazer79
    1,816
    Well, coming from the one and only Grim-Reaper, I'm honored to recieve such a great award [​IMG].
    Well, there you have it: more praise to you haha [​IMG].
  16. chaka73
    377
    Southern California
    How do I find out what kind of part time kit I have I dont really know anything about those kits but like blazer79 said I have to find out to see in which position my lever should be in so I wont drive in 4x4 all the time.
    keep blazin !!!
