Is the rear disc kit swappable?
Discussion in 'The Garage' started by fixmy59bug, May 2, 2007.
  1. fixmy59bug
    fixmy59bug Registered Member
    Feb 28, 2006
    88
    Riverside, Ca
    I am looking at a rear disc brake kit on Ebay for $295 for my 14 bolt full floater. My question is, right now my rear end is a single rear wheel, but in the near future I am going to swap it to a dual rear wheel setup and would like to keep the rear discs. The reason it is so cheap is because there is no provision for an E-brake, however ever since my lift kit (and rear axle swap) I have not had a parking brake anyways. A kit with parking brake is $200 more so I may go that route if need be.
    So is this kit swappable from SRW to DRW? I have not seen any information stating it is specifically for SRW or DRW. Thanks alot.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I'm pretty sure they each use their own kit.
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    The duallies require entirely different rotors, and caliper locations change from SRW to DRW.
    If you're going to run single wheels on the DRW, just for the wider WMS, then you could re-use the stuff, as long as it's not a weld-on kit.
    The kit for parking brake just uses the El Dorado calipers instead of the front ones, btw.
    In short, the off-the-shelf kits are generally for SRW, period. DRW is fairly complicated due to the depth of the wheels.
    -- A
  4. fixmy59bug
    Feb 28, 2006
    88
    Riverside, Ca
    Well, that settles that. No rear disc brakes for me yet.
    Is there an available kit for rear disc brakes for a DRW 14BFF? Or will I have to buy the kit and make the brackets myself? I would much rather buy an available kit.
    Thanks again.
  5. dremu
    Feb 27, 2000
    15,958
    452
    The biggest issue is the rotors; you either need some serious spacers or rotors with some deeeeep hats. I ended up using rotors from an '03 Express Van, IIRC.
    http://www.slosh.com/ck5/caddy-calipers-installed-5.JPG
    http://www.slosh.com/ck5/rear-disc-bits-painted-2.JPG
    Blackbirds has dually kits:
    http://www.blackbirdscustomtrucks.com/index7.html#7dually
    I am not aware of anybody else that sells complete kits for duallies.
    They claim theirs fit into 16" wheels; I had to clearance my calipers and still ended up with a 1/4" spacer (see the first pic) to make mine work, but then mine is all custom weld-on as nobody had a kit when I did my dually conversion.
    -- A
