Is the Spicer 760x strong enough for a......
Discussion in 'The Garage' started by stallion85, Dec 12, 2005.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Chromo shaft? I busted my POS OX U joint and once I get that contraption out of my axle shaft I am planning on putting a Spicer 760x in there. Is the general concensus this is probably the strongest u joint other than CTM and OX? I am NO way going to buy another OX and really don't want to drop $200 on a CTM. My long side right now still has a CTM and I do have another CTM cross section(minus)caps and those little o rings.
    So will I be ok running this U joint? I guess it really doesn't matter as long as I don't fugger up the ears on the shafts if I blow this U joint...:doah:
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What shafts are you running. Some wont worrenty there shafts if you run a stock spicer joint.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Depends on the shafts. If we are talking superiors, go CTM, for warn/yukon go for the spicer. You can also get the bronze bushings for them (to replace the needle bearings) and have them cryo'd.
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    These are for Warn Shafts.....I picked two of them up about an hour ago.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you cvan buy all the parts for a ctm. so if you have a cross section you can buy the caps which will save you some money
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    my thoughts to the "T"
    Grant
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I knew you could buy a rebuild kit, but it doesn't include the caps. I will send Stephen an email and get a price from him.
