Is The Transfer Case Binding Up???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Canuck, Sep 8, 2000.
  1. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    Howdy All!!
    I came home last night and the mile road into my house is pretty rough due to the recent rains. Of course I don't slow down and I hit one helluva deep pot hole. I lost all forward power. I coasted into my lane and it was like the tranny went out. Depressing because I just put it in. I couldn't get a gear. It ground into park, but it didn't work either. I shut it off, walked to the garage, got a light and checked the linkage, no problem, checked fluid level, again good.
    I remembered that it did this to me a year ago. I locked the hubs, put it in 4hi and it worked fine. I drove it up to my garage, unlocked the hubs and put it back into 2wd. Everything worked fine.
    My question is WHAAAAZ UUUUPPP???? Seems pretty strange.
    It's a 1986 Silverado, 305ci, 208, Warn hubs, 700R.
    Thanks guys,
    Any input would be appreciated.
    Go Wide or Stay @ Home
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I bet your T-case popped out of gear. That happened to me not too long ago...
    Next time it happens check your t-case shifter and make sure it is in gear.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Canuck
    183
    Actually I did check that, and it was still in 2wd. I tried moving the gear selector and the transfer case just whined or grind. It wasn't till I got out and locked the hubs did the selector actually go into 4x4.
    Canuck
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    What gear did you have the tranny in when youtryied putting it in 4wd. I know with my 208 if I dont have it in N or Park, it wont go into any gear in the t-case until I put it in either park or Nuetral.
    Mike [​IMG]
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I'm sure your transfer case slipped into neutral. My dog shifted my NP241 into N one time (one notch forward from 2HI), and it took me a few minutes to figure out what went wrong. Bad dog.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  6. Canuck
    183
    Even though there were no gears, I could tell it was in N when I put it in 4x4. The transfer case was "definately" not accidently shifted out of gear, that's why it's so strange.
    Canuck
  7. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I think they call it a range fork selector. Mine popped out of gear many years back, if I put it down to 4lo and drove around then shifted back to 2hi it was fine for a day or two. Eventually I had to tear the t case down and replace it. I think it was 60 dollars. Good luck
    creepin' and crawlin'
    Jim
