IS their Such a Valve ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Apr 19, 2002.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    I was wondering is there a valve that is made so that i can switch it and thus bypass my mufflers but when i need to go through the mufflers i can switch it and have it flow through them.
    do they make these? if so where can i get one
  2. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Closest thing I've seen is headers with caps. They have a "y" at the end, one leg goes to the muffler and the other can be opened to bypass the exhaust system. Not too sure of their availability for our rigs.
    It sure would be neat if you get something that was cable operated. That would be fun at the stoplight next to the riced out mustangs, uncap the headers and blast off
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    JC Whitney sells one that is cable operated and Iv seen some in street rod mags that are electric.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,069
    479
    Grand Rapids area
    Yeah, try JC Whitney. I think that they are cast iron. Not sure what diameters they come in. I would be skeptical of them actually sealing when closed, especially after the heat and/or salt start the corrosion process. I suppose you would want to use that anti-seize they put on the manifold outlet bolts on the little flapper valve.
  5. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    ill check that out, i wonder if there is a manual one?
    this is something im interested in.
    mayve have a set of pipes that go next to the muffler to bypass to.
  6. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    this has been an idea ive been toying around with.
    ill be discussing with my dad, see what he thinks.
    i think i would be awesome tho, im goin to check it out more today
  7. Blue85
    Jul 26, 2000
    9,069
    479
    Grand Rapids area
    Flow Tech make a muffler that passes in an "S" shape, but there is a panel on the back with three wing nuts. Remove them and the flow is straight through.
    You could also have an exhaust shop install custom "Y" pieces with a removable cap on one branch that is held on with wing nuts.
  8. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    now thats a good idea!
    i might try that!
    do i have to weld them or can i use exhaust clamps?
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
  10. Blue85
    Jul 26, 2000
    9,069
    479
    Grand Rapids area
    That looks like the same one in JC Whitney. Too bad it is only for 2" o.d. pipe.
  11. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    The valve you're looking for is an Exhaust Dump. They are very common on the drag strip, and you should be able to get one for your K5 from a speed shop. Or, go to the drag races one night, and start asking around.
    Thomas.
  12. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    my bro had one on his old race camaro. open up in the country and close it in town. It was from jc whitney
    NITRO
  13. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Its actually called a cutout. A dump is when there is a short turn down right after the muffler and under the car.
  14. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
