Is there a 17x10? Will 16x10 aluminum wheels fit 8 lug axles?
Discussion in 'The Garage' started by divorced, Jan 22, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Does anyone make affordable 17 x 10 wheels? All I can find is 17 x9. I found a few that were 9.5 wide but cost $230 each!
    Will a 16x10 aluminum wheels fit an 8 lug D44 and disc brake 14 Bolt FF with no caliper grinding?
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have 16x10 Mickey Thomson Classic IIs on my set up. I think they have around 4.25" back spacing. They have plenty of room.
    I am running a D60 up front and Corp FF 14 bolt with disc brakes in the back.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    17x9 or 17x8s are all I've found. But I want 17x8s so I'm fine with that.
  4. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    allied wheel makes the cheapest steel wheel i found...
  5. divorced
    Jul 20, 2004
    5,115
    That's cool, the M/T II's are what I want. I can see some Irok's in my future... :saweet:
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Weld Racing makes a bunch of rim styles in 17x10", 12", and 14".
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    yes
  8. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    I run 17 x 10 American Eagles. I paid $159.95 each, try 4 Wheel Parts, they might not advertise them but they should be able to order them. I must warn you, I had to wait a month before they could find a set that wasn't on it's way to somebody else, and ship them to me.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    17x8 or 17x9 should be all you need for most tires. What tires you running?
  10. chevydan3
    Nov 27, 2004
    409
    Reno, Nevada
    I am currently running 35 x 12.5 Pro Comp Mudders. I may step up to taller/wider tires, so I chose the 17 x 10. The 17 x 9's that I looked at had way too much backspacing, 5-5.5 inches. My wheels have 4.5 backspacing, I would prefer 3.5-4 inches but I had to compromise somewhere. I like my wheels alot, but I would like to have an aluminum beadlock kit. I like the look of beadlocks and the ability to air down safely.
