Is there a 350 in the world that doesn't leak oil?
Discussion in 'The Garage' started by Mastiff, Apr 1, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Is there a 350 in the world that doesn\'t leak oil?
    I've had 3 different small blocks in my K5 and every single one has leaked. The one I have in there now is a fresh 350 from a reputable shop. It was good for a few thousand miles, but now I switched to synthetic oil and bingo, leakage. Only about two drops every time I pull into the garage, but still... /forums/images/graemlins/mad.gif Never anyplace easy either, looks like rear main or something (settles onto bell housing).
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: Is there a 350 in the world that doesn\'t leak oil?
    ive used victor resin gaskets and felpro gaskets, the felpros last alot longer before leaking
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    It's not called leakin. It's called markin it's territory. Yes they all do it. It's also called constantly changin it's own oil. Good luck to ya in the future.
    Allan
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The stock 350 in our '94 Sub, with 124K miles on the clock, doesn't leave any drops on the driveway since I had a hydraulic hose shop rebuild the POS factory oil cooler lines. Before that it dripped all the damn time. /forums/images/graemlins/angryfire.gif
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Chevrolet
    Cranks
    Hard
    Every
    Valve
    Rattles
    Oil
    Leaks
    Every
    Time
    /forums/images/graemlins/waytogo.gif
  6. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Mine doesn't really leak, it more or less just seaps out, nothing drops on my driveway from the motor, but the oil pan has some residule covering it, was mostly from the rear main seal before i replaced it though.
    211,000 miles never been torn apart /forums/images/graemlins/yikes.gif
    Just waitin for it any day to do SOMETHING /forums/images/graemlins/doah.gif
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    189K miles and a new timing chain (so I cut and replaced the front pan gasket) and still no leaks. The tail shaft on my 208 is putting some oil under the truck but nothing up front. I do have a radiator leak now though /forums/images/graemlins/thinking.gif /forums/images/graemlins/rolleyes.gif
    The project truck leaks, I think its because the tranny lines are rusted and leaking though
  8. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Mine doesn't leak /forums/images/graemlins/thumb.gif
    Leaked a lot though when I pulled the cover and cranked it to check for a bad cam /forums/images/graemlins/doah.gif
    Mine was a rebuilt engine though, if your tired of it leaking oil then just replace all the seals on it. Also helps to prevent dirt and stuff from getting in it. Their real bad to leak at the corners on the back of the intake sometimes too. And a lot of times it turns out to just be valve covers.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Since you and I resealed my upper end, no more leaks from motor. My ps box got leaky again, wonder how many times I'm gonna try brake fluid before we do that seal /forums/images/graemlins/waytogo.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No leaks since I went to a 1 piece rear main seal engine.
    I use Fel-Pro gaskets ONLY even though my work sells only Victor.
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    My buddies Camaro doesnt leak a drop of anything. Kinda nice.
  12. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Motor dosen't leak, everything else however /forums/images/graemlins/peace.gif
  13. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    funny post. i was doing all the general stuff today(oil, filter, lube, rear gear oil change) and also the usual cleaning of the slow leaks. Never makes the driveway, but just gathers here and there.
    -rear dif leaks at the pinion...seeps more like it
    -rear output of tcase seeps also
    -radiator hose(top one) drips ever so slightly
    -oil is leaking from somewhere of rear drivers side. I cleaned up and will try to track it in a couple of days.
    -water leaks into cab betweeen hard top and cab
    -water leaks in from front of cap somewhere
    leaks, leaks, leaks.
  14. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    RTV
    mine doesn't leak
  15. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    How much did it cost you to rebuild your cooler lines? /forums/images/graemlins/dunno.gif That's the only small leak I have right now! /forums/images/graemlins/crazy.gif The factory lines are no longer in existence! /forums/images/graemlins/angryfire.gif
    Bill
  16. 350350
    350350 1/2 ton status
    Sep 25, 2003
    939
    USA
    A small block chevy that didn't leak oil would be sacriligous... /forums/images/graemlins/thinking.gif
  17. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I guess its like harleys(even though ive never ownded or even ridden one)
    If its not leaking your out /forums/images/graemlins/eek.gif
  18. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I removed the lines from the truck and dropped them off at the shop in the morning. That afternoon the rubber on both lines had been replaced with Aeroquip hydraulic hose and new crimped fittings. Cost me a whopping $28. /forums/images/graemlins/thumb.gif
    GM phuqued me for $90 for a new set of lines on my '91 S-Jimmy. About a year later one of them started leaking. /forums/images/graemlins/angryfire.gif
  19. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Thanx man, I'll look around here for a shop to do mine!
    Bill
  20. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I had found a local hydro shop that was willing to produce a new set for just over $100... so I decided to remove the oil cooler adapter from the block, and just slapped in the lil piece to attach the filter direct. Damn I'm cheap.
    But to the subject of this thread... my '89 Burb with 84,000 has no OIL leaks... /forums/images/graemlins/laugh.gif and my K5 is on its way to having no leaks at all. 1pc rear main block, well sealed Th400... they only thing still leaking is my bent hydro assist ram! /forums/images/graemlins/angryfire.gif
    -Dan
